Security System... Do I or Don't I?
Old 03-09-2016, 07:07 AM
Carter Stindberg's Avatar
Carter Stindberg
Carter Stindberg is offline
Default Security System... Do I or Don't I?
My 2007 Road King Police didn't come with any key fobs, and the bike starts and runs fine so I don't even know for sure whether it even has a security system or not.
When I turn the ign. key on, a little "key" image at the lower right of the speedo comes on in red for a second or two and then just goes away. Doesn't blink, just comes on with the ign. and then goes away.
Is there a simple way that I can tell if this bike ever had a security system?
I don't even care if it doesn't. I just don't want to be left stranded dead somewhere if it accidently gets activated.
TIA
Old 03-09-2016, 08:05 AM
Kerr8005's Avatar
Kerr8005
Kerr8005 is offline
If it's anything like the touring bikes, I believe the siren is inside of the left side cover. My '12 Ultra has the Key image that lights in red, but doesn't have security. Which someday I'd like to add, just so I do not have to lock my ign. to secure the bike.
Old 03-09-2016, 08:31 AM
TcHunter's Avatar
TcHunter
TcHunter is offline
TIA
Most likely you have no security on the bike, no fobs no security. If you had a siren I would think you would have a fob for sure.
Red key icon is eaxtly that just a dummy light, if you had security the light would blink when the bike is an the off position.
Old 03-09-2016, 09:10 AM
SIDECAR BOB's Avatar
SIDECAR BOB
SIDECAR BOB is offline
to be sure you could look under the seat and check the turn signal tip over module get the part number and check it at the dealer, but others said said the red key coming on and going off when ignition is first turned on is normal for a bike without security. Also it can have security without a siren, the siren was an additional option.
Old 03-09-2016, 11:53 AM
skratch's Avatar
skratch
skratch is offline
Received 4,193 Likes on 2,457 Posts
07 was the first year for the proximity fob. there is no way to 'disarm' the system and leave it disarmed as you could with the 06 and below.
so unless there is a fob zip tied somewhere on the bike, you do not have security. like sidecar bob suggested, get the pn off the tsm to be 110%.
Old 03-09-2016, 02:34 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,412 Likes on 881 Posts
why would a cop bike have security? it's not like they park them at bars or out of the way hotels...
Old 03-09-2016, 06:28 PM
Carter Stindberg
Originally Posted by SIDECAR BOB
... but others said said the red key coming on and going off when ignition is first turned on is normal for a bike without security. Also it can have security without a siren, the siren was an additional option.
Yea, that sounds like what I (don't) have.
The red "key" light never blinks, it just comes on for a moment and then disappears.
I know that there isn't a siren, so my final check will be to verify the turn signal part number.
I did get the original Police Owners Manual with the bike that came with it, and it covers the use of the Security System in detail. That's why I thought it "might" have the option.
In the end, I wouldn't be disappointed not to have it because I'm never really away from the bike except for when it's in my garage.
Thanks guys.
Daniel K
03-06-2019 07:21 AM
fncha0s
VRSC Models
04-14-2018 11:50 PM
Dolce
Electrical/Lighting/Alarm
06-08-2016 08:03 PM
flyboyron
05-02-2014 10:09 AM
big_e78
06-19-2009 11:25 AM
Quick Reply: Security System... Do I or Don't I?
