Fork oil change
Fork oil change
I changed my fork oil on my 13 CVO ultra and now I have a clunk in the front when going slow over bumps, checked everything out and nothing is loose. At higher speeds everything seems fine, no clunk.l used SE heavy fork oil and added 10.7 oz. to each fork leg, any ideas or has someone else experienced this?
Thanks
Thanks
Oil weights ratings can be confusing and I think Viscosity Index may be more accurate for suspension fluids. You can search to find ratings comparisons.
If you have a clunk, your fork oil may be too heavy. Try Bel-Ray 15W or Spectro 15W (or Spectro Type E) or another equivalent suspension fluid. I prefer not to use HD as it's too much of a guessing game.
RayK (05-02-2016)
Just to eliminate one possible noise-maker on low speed bumps....
If you haven't already done so, try lightly applying the front brake over the same bumps that cause the front-end noise.
Sometimes the caliper/pads/rotor assembly is loose, or has some play that can bang around a bit over bumps.
All the best,
Shane
All the best,
Shane
RayK (05-02-2016)
