Noise coming from trans maybe
Old 02-18-2017, 05:47 PM
big- mike's Avatar
big- mike
big- mike is offline
Default Noise coming from trans maybe
I've been chasing a noise and can't identify. I have a 2010 ultra. At the end of last season I had some bearing issues so I tore it down and did the trans main bearing inner primary bearing clutch bearing and I went with to upgraded compensator. The noise I hear is only when I deceleration from 5th or 6th and it sounds kinda like the compensator (sounds like rocks in the primary) it never sounds like that upon acceleration smoothed as silk. Now I know Harley uses different cuts on the gears. Maybe it's a normal sound and I'm just listening too close. Just looking for opinions. And yes I did change to 90/140 gear lube in the trans and that seemed to help. I did pull the trans to change the main bearing it seemed to be pretty cut and dry everything came out pretty strieght forward if I only would have rememberer to remove the dip stick nothing would have gone wrong. And yes I broke the dip stick but retrieved the broken piece. Any input would be helpful. I don't here it all the time never when it's cold.
Old 02-19-2017, 12:13 PM
big- mike's Avatar
big- mike
Any opinions? Or is it normal?
Old 02-19-2017, 12:19 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Originally Posted by big- mike
...never when it's cold....
when fluid is thicker
its like old trick of sales trick of sawdust in a car transmission to quiet worn gears
could be actual wear or just "chatter" from parts moving around- tranny linkages and dogs may be damaged by impact tools on the tranny main
mike
Old 02-19-2017, 06:44 PM
big- mike's Avatar
big- mike
It's hard to discribe and I'm thinking it's a normal sound I'm just paying too much attention to it now. The trans shifts fine I figure it it's something that's going to grenade I'll know at that point. Just hope I'm not on a trip when it happens but it's not going to stop me .
Old 02-19-2017, 06:57 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 16,763 Likes on 6,897 Posts
There's is a problem with the 2010 transmissions. I know first hand. Ours failed at 20k miles and they had to go back into it a two 36k. I am not hard on my bike and always on time with service.
Was told by dealer that it was the needle bearing in the main shaft. I cannot remember what the actual noise sounded like but I clearly knew I had a problem and so did everyone riding with me. The first time it trashed the shaft which the bearing rides directly on. There are intragal gears on the shaft and it all has to be replaced. Not exactly what happened the second time but both were covered under our extended warranty.
I did switch to Bell-Ray Gear Saver Oil at the dealer suggestion and had 56k miles on the bike when we traded it with no issues. I know I had a thread on this about three years ago if it comes up in the search.
Old 02-20-2017, 05:55 PM
big- mike's Avatar
big- mike
You might be on to something I was in there last august and replaced the trans main bearing and the inner primary bearing and race and clutch main bearing I missed the needle bearing in the main shaft. The bummer is there is no way to get the main shaft out without destroying the trans main bearing. It's pretty cut and dry to take apart once you get the inner primary race off but everything has got to come off bags and exhaust starter and the whole primary
Old 02-21-2017, 12:26 AM
Guntoter's Avatar
Guntoter
Guntoter is offline
Did/do you have chunks of metal on the drain plug magnet? If so, you have a bearing issue. Those needle bearings are **** and do go bad, at least on the earlier ones. A 2009 I was working on had large chunks of metal on the magnet and it turned out to be one of the needle bearings on the mainshaft disintegrated.
Old 02-21-2017, 11:48 AM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
I've noticed small shavings on my plug but no big chunks. Seems like the plug used to be clean at oil change but I can't remember.
Old 02-21-2017, 12:37 PM
Roadflyer's Avatar
Roadflyer
Roadflyer is offline
Have you checked the primary chain tensioner?
Old 02-21-2017, 06:29 PM
big- mike's Avatar
big- mike
I have replaced the tensioner and the compensator with the upgraded version. The noise sounds like a compensator rattle but only when I'm coming down out of 6 tho and 5 the down shifting when I go from 4th to 3 it goes away. My thinking now is as the bike slows down the output shaft slows too and the outpu shat roller bearing were the only ones I didn't change so it looks like in going back into the trans.
DustyMe
03-24-2016 04:53 AM
Jabrnet
08-06-2014 05:04 AM
o/d
01-29-2014 07:02 PM
Cygnus x-1
EVO
14
09-08-2011 04:46 AM
doorsidedown
10-13-2009 10:48 PM
Quick Reply: Noise coming from trans maybe
