YUASA GYZ32HL battery for 2006 Ultra?
I know this battery is supposed to fit according to the manufacturer's information, but I wonder if it fits the same as my HD OEM battery? That existing HD battery is already a very tight fit. In fact I had to fabricate some bolts with handles to pull the OEM battery out last time I removed it.
Thanks.
Thanks.
I believe there were frame changes after 2006, so perhaps the battery box is different. Just need to find out before I buy a battery online that will not fit. Maybe someone has a battery setting on the floor somewhere that could be measured. I cannot seem to find the OEM dimensions online. Thank you.
same battery all touring models since 1997
some models use a nylon pull strap under the battery, do not trust it it'll chafe under the batter and maybe drop your battery on the tank
some pull by the lugs.
I used a piece of 2" guitar strap under mine
which is a yuasa gyz32hl
IF your battery is swollen, it could be a charging system problem or bad chemistry inside the battery and it s not venting
mike
mike
