Question about Neck bearings and fork alignment
Old 01-23-2008, 01:10 PM
Mississippi Bagger's Avatar
Mississippi Bagger
Mississippi Bagger is offline
Default Question about Neck bearings and fork alignment
Is it possible for the adjustment (tightening) of the neck(steering head) bearings to have an effect on the triple tree?
The top right fork is now sitting a bit closer to the tank than the top left fork. It appears that the triple trees are not aligned properly.
Could this have happened when the neck bearings were adjusted/tightened?
Thanks
Old 01-23-2008, 01:29 PM
Neil's Avatar
Neil
Neil is offline
Default RE: Question about Neck bearings and fork alignment
When do you notice this? Is it when you are moving down the roador when it is sitting parked? Does the bike still track straight?
Old 01-23-2008, 01:38 PM
dgoodbmw's Avatar
dgoodbmw
dgoodbmw is offline
There is actually no way that can be. When the stem bearings are in and adj. they pull the triple trees straight.If that is actually what you are seeing, then i suspect something is bent or the image you get from the gas tank is a figment. The adj. doesnt have any effect on the tubes moving closer to the tank.
Old 01-23-2008, 02:24 PM
twincam47's Avatar
twincam47
twincam47 is offline
ORIGINAL: dgoodbmw
You are right.
Just keep in mind that while you adjust the neck bearings thelower pinch bolts have to be loosened so that the triples will actually keep straight (parallel) otherwise you are loading the trees against each other.
Old 01-23-2008, 04:16 PM
Mississippi Bagger
ORIGINAL: twincam47
ORIGINAL: dgoodbmw
You are right.
It is stable and seems to be tracking just fine.
I noticed it after getting it back from the stealer who mounted my new tires.
The top of the right fork is about 3/8 of an inch back from the top of the left fork. Seems like the triples are NOT exactly parallel. (you can also see this in the handlebars)
I have not dropped it, dunno what happened when the stealer had it. Will not take it back to them....when they had it for the tires the scratched the tank to the metal and broke my tourpack LED light and glued it back together (never fessed up to it either).
Old 01-23-2008, 04:52 PM
DeJavu's Avatar
DeJavu
DeJavu is offline
Though not usual, it is possible for the forks to be off parallel. I use a piece precision ground 3/4" thick glass to align mine(have used it on many of my bikes over the years) but a careful visual alignment can be just as effective. Loosen enough to be able to twist the forks(hands on handlebars, wheel between your knees. Repeat until the forks are aligned visually from the side, tighten the trees, check again, repeat if necessary.
With the ground glass you can place it over the front of both forks and by tapping you can tell if they are parallel(dull thud good, ticking sound not). Haven't tried it with a thick piece of tempered glass(glass shop will have) but it should work as well. Good Luck, it ain't rocket science!
Old 01-23-2008, 05:02 PM
electaRICK's Avatar
electaRICK
electaRICK is offline
I had a Cervical fusion done on my neck,, Brg's are fugged up now, and I my fork is misaligned , cause I keep hittin my tooth..... friken quack Doc's anywho!!
Old 01-24-2008, 03:30 AM
Mississippi Bagger
ORIGINAL: DeJavu
Thank you!
13RoadKing
03-09-2017 10:35 PM
bellgnte
05-24-2016 10:04 AM
Alain
10-03-2014 10:08 AM
Turret_plug
09-01-2012 03:54 PM
spot1970
08-10-2008 02:53 AM
Quick Reply: Question about Neck bearings and fork alignment
