Found Problem, Now What? - Vibration Around 2500 RPM
Old 06-04-2008, 07:38 AM
rahall's Avatar
rahall
rahall is offline
Default Found Problem, Now What? - Vibration Around 2500 RPM
I get a vibration when the engine hits around 2500 RPMs.
I notice the vibration most in the footboards and grips.
The bike does not even need to be moving for the problem to show.
The engine just needs to hit 2400-2500 RPMs.
Before and after that RPM range, there is no problem.
I did a search and read several posts on similar problems, but most were older.
If anyone has had this type of problem or could suggest some things to look at, I would greatly appreciate it.
Old 06-04-2008, 08:06 AM
djhrln's Avatar
djhrln
djhrln is offline
Default RE: Vibration Around 2500 RPM
Exhaust system is a good place to start, make sure everything is tightened to specs.
Old 06-04-2008, 08:20 AM
Pyper's Avatar
Pyper
Pyper is offline
Have you checked the torque on your engine mounts ?
Old 06-04-2008, 09:01 AM
rahall's Avatar
rahall
rahall is offline
No on the mounts.
Good idea.
Anyone else?
Old 06-04-2008, 10:13 AM
Snickers1948's Avatar
Snickers1948
Snickers1948 is offline
I saw a post of the same problem on another forum....same pipes and exhaust.....problem was with the bracket which mounts the right pipe to the frame near the clutch cover...seems the bracket from the V & H system needs a small spacer to set the bracket OUT in order to align the pipe so it will not put a load on the bracket...Both posters said they found the bracket broken at the tranny bolt and when welded and spacer added to align everything properly... NO VIBRATION....Seems without the spacer (washer. ect) the bracket is about 1/4 In from the tranny...so tightening the bracket puts a tension onit and when it breaks....it transmits the vibes to the frame and the floarboards.....
Hope it helps........
Nick
Old 06-04-2008, 11:19 AM
rahall's Avatar
rahall
rahall is offline
Thank you Nick.
That is a possibility.
I had issues with that bracket when I first installed the pipes.
The washers did not set flat because of the 90 degree angle in the bracket.
This actually caused a transmission fluid leak since it used a couple of the transmission bolts to secure the bracket.
I appreciate the input.
The vibration is not that bad, but it's new and just bugs me.
Old 06-04-2008, 03:02 PM
patrol557's Avatar
patrol557
patrol557 is offline
Hopefully you checked that actual engine mount itself. I have a 2006 and the mount was junk. It caused the same vibration your taking about. The new mounts have a washer over them so that it keep the oil off of the rubber mount so hopefully it will not wear out as fast.
Old 06-04-2008, 03:14 PM
BLACK 3's Avatar
BLACK 3
BLACK 3 is offline
i have a similar vibration and found it to be the highwat pegs and the engine gaurd
i put my feet on the pegs and the vibration goes away
i hope this helps
Shawn
Old 06-04-2008, 08:15 PM
*Shadow*'s Avatar
*Shadow*
*Shadow* is offline
I had the same problem with my 06, 10000 miles, change the mounth and vibration was gone
Old 06-04-2008, 08:37 PM
biz44's Avatar
biz44
biz44 is offline
I had a vibration that was about the same as yours........all I did was top-off the tranny fluid and it went away.
Quick Reply: Found Problem, Now What? - Vibration Around 2500 RPM
