So what's a Hog weigh anyhow?
Old 07-11-2009, 06:35 PM
DuraGlide's Avatar
DuraGlide
DuraGlide is offline
Default So what's a Hog weigh anyhow?
Got bored at work the other night and with all the discusion about tires and weight ratings I thought I'd see what a Hog really weighed. I've got a 2008 StreetGlide and the factory says 749lb shipped. I've got the normal stuff in the bags(chaps, jacket, gloves, tools ,etc.)and it weighs 25lbs. With 3gal gas and ready to ride, the bike weighs 815 lbs. Front weight was 362lbs and the rear weight was 453lbs. Added my 198lbs to the seat and total weight was 1013lbs. Front weight went up to 420 lbs and the rear weight went up to 593lbs. Factory manual lists the GVWR at 1259 lbs with front GWR at 500lb and rear GWR at 827lb for ALL 08 touring bikes. Don't look like it would take much gear or a passenger to put you over the GVWR.
Old 07-11-2009, 06:39 PM
ko4qc's Avatar
ko4qc
ko4qc is offline
I may be wrong but dont think so...I dont believe you can weigh the front and back,add them together and get an accurate weight...there is carry over weight from the other end...:>)
Old 07-11-2009, 07:05 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
you can weigh the bike on 2 scales at the same time and get accurate balance info. That's how it is done at truck stops and portable scales.
I know my 03 weighs 820 "wet" shipping weight is usually with no fuel, and assume gas weighs 6 pounds a gallon give or take so a full tank is 30 pounds,
Old 07-11-2009, 07:34 PM
DuraGlide's Avatar
DuraGlide
Weighed the bike on one scale for total weight and 2 scales for the split weight. There was a couple of pounds variance but not really enough to be a problem.
Old 07-11-2009, 07:53 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
Damn, no wonder I need ABS Bremos. :^O
Old 07-11-2009, 07:57 PM
teamstersteward's Avatar
teamstersteward
teamstersteward is offline
shoot guess I'll have to walk don't want to exceed weight limits
Old 07-11-2009, 08:01 PM
bagman1's Avatar
bagman1
bagman1 is offline
Ive always done it by weighing the front axle only, then pull the rear on and subtract the difference to get the rear weight. Ive been out of the trucking business for a while but I dont think its changed.
Old 07-11-2009, 08:44 PM
tda69's Avatar
tda69
tda69 is offline
In aviation, we calculate weight and balances fore and aft of the CG limit. Very important to know when flying. Don't know where the CG is on my bike, but it certainly could be determined. Anything forward of the CG would be considered the front, anything aft would be considered rear. I never really thought of my bike this way before, but I suppose you could calculate a CG for just about anything.
Old 07-11-2009, 09:23 PM
ko4qc's Avatar
ko4qc
ko4qc is offline
Went thru this in Technical Physics years ago in College.....there is a formula for everything...problem is,I barely remember the name of the class,much less the formulas.....passed it and forgot it...:>)
Old 07-11-2009, 09:40 PM
dog155's Avatar
dog155
dog155 is offline
Plenty! when you have to push them,light as a feather cruising down the asphalt.
Quick Reply: So what's a Hog weigh anyhow?
