Twin Cam 88 remanufacture program
Old 08-25-2009, 03:44 AM
CroK's Avatar
CroK
CroK is offline
Originally Posted by jdreed520
That was going to be my next question was what oil is he running?
I am in southeastern florida where temps this time of year are pretty warm. I'm currently running HD straight 60 weight. I've also got the baisley or LMR-004 spring for extra oil pressure installed.
Old 08-25-2009, 07:36 AM
huffhuff's Avatar
huffhuff
huffhuff is offline
roller lifters are inherently noisy. increase lift and you might increase noise that telegraphs up the pushrods to the valve rockers. add a fairing to a Road King and for a while you will think the engine is coming apart.
Old 08-25-2009, 10:37 AM
Yachtman's Avatar
Yachtman
Yachtman is offline
Crok,
Anywhere near Jupiter, Fl?
Old 08-26-2009, 11:22 AM
CroK's Avatar
CroK
CroK is offline
Originally Posted by Yachtman
Crok,
Just up the road from you/jupiter about 45 minutes. Ft Pierce
Old 08-26-2009, 11:24 AM
CroK's Avatar
CroK
CroK is offline
I hear ya! I ride with my windshield alot and it certainly does channel the sound straight up to the driver's ears!
Old 08-26-2009, 12:03 PM
carpetride's Avatar
carpetride
carpetride is offline
With all the time and money you put in your current motor, I would just run it.
That $2700++ cash you'd spend on a rebuild would be better put towards a new bike. in my most humble opinion.
Old 08-27-2009, 01:47 AM
Avmech97's Avatar
Avmech97
Avmech97 is offline
As I understand it, when an engine goes in for a factory reman, any upgrades that have been done will not or may not come back with the eng. I'm told they go back to factory stock unless you are having the 95 in. done which can only be done on the injected engs. due to emmissions regs. I agree with the others that your mileage is pretty early for a reman. Mine had 119,000+ before I had the reman. done. Good luck with whatever choice you make.
barrygreen
Engine Mechanical Topics
16
02-11-2018 02:17 PM
Histicku77
25
10-01-2015 09:00 PM
jbmunnoch
11-16-2010 08:25 AM
da_big_Guy
08-30-2010 06:16 PM
Neil
12-14-2008 03:16 PM
Quick Reply: Twin Cam 88 remanufacture program
