SOLVED - RH passenger board ViBrAtEs (bad)??
Old 06-30-2006, 01:15 PM
4x4Given's Avatar
4x4Given
4x4Given is offline
Default SOLVED - RH passenger board ViBrAtEs (bad)??
I just bought a (nice) '95 Ultra and the other evening I took the love of my life for a ride. Well within a block she asked me why the RH footboard was vibrating a LOT more than the LH. Hmmm.... She said it was enought that it was uncomfortable. So last night, I was riding home from work and I flipped 'em down and set my feet back there and sure enough, the RH board vibrates pretty darn bad (about 2x - 3x harder than the LH) from about 1,200 RPM up to about 2,400 RPM. Below or above that range, they are about the same and not really an issue.
Oh... the passenger boards are factory and the mounting bolts are tight. The front boards, which are after market (not sure of the brand) and are what I would call "floating" (dual plate with rubber isolators in between) and they are *SM-O-O-O-O-OTH.
Any ideas or suggestions would be greatly appreciated. Witty, entertaining remarks are also appreciated.
Old 06-30-2006, 01:25 PM
mcman's Avatar
mcman
mcman is offline
Default RE: RH passenger board ViBrAtEs (bad)??
Haven't got a clue on that one. My wife hasn't said anything about vibration in the footborads. We just picked up our '06 Ultra a few days ago. Still trying to get the Tourpak extension ordered and installed and trying to keep from taking the lowers off because of the heat for the wife. I do believe they have solved the heat problem for the rider with the vented lowers but the little wife is still getting blistered from the reay cylinder.
Old 06-30-2006, 01:36 PM
4x4Given's Avatar
4x4Given
4x4Given is offline
I don't have the lowers on mine (I think the original owner removed them) and yeah, Tina said that at slow speeds, she was getting a LOT of heat on her right calf. Of course she was wearing sandals and capris too. I told her that shoes, socks and jeans would prevent that.
I'm going to start with a close instpection of the motor/trans/swing arm mounts and if I can't identify the cause, I will probably install a set of floaters like I have on the front.
Old 07-01-2006, 06:13 PM
4x4Given's Avatar
4x4Given
4x4Given is offline
Problem solved. Duh! The mounting bolts were a little loose. Tightened them up and no more vibes!
Old 07-02-2006, 01:21 AM
FireHawk's Avatar
FireHawk
FireHawk is offline
Great news!
And I'm liking the look of your ride. I was wondering how an Ultra would look with wide white walls. Sweet!
Old 07-02-2006, 02:06 AM
RDKingRider's Avatar
RDKingRider
RDKingRider is offline
ORIGINAL: FireHawk
Great news!
I agree, showed the wife and she is in love. Really sharp looking ride. Glad you found the problem.
Old 07-02-2006, 10:44 AM
Bruce00's Avatar
Bruce00
Bruce00 is offline
ORIGINAL: 4x4Given
Glad to hear you found and fixed the problem.
Iam sure your wife wouldn't have liked my solution..........pull the rear footboards and install a solo seat
DannyZ71
08-29-2011 07:08 AM
MADHOG
05-26-2011 08:29 AM
edsstuff57
10-26-2009 06:28 PM
mcman
08-09-2006 12:54 AM
mcman
07-09-2006 01:25 AM
Quick Reply: SOLVED - RH passenger board ViBrAtEs (bad)??
