'05 FLHRSI Front brake squeal
Old 05-23-2005, 10:54 AM
scottcfd's Avatar
scottcfd
scottcfd is offline
Stage I
Default '05 FLHRSI Front brake squeal
The front brake on my bike squeal constantly, at low speed it will make your ears bleed. The dealer said that they have had a problem and new pads are still doing the same thing. They have turn the problem over to the H-D area rep. Has anyone else had this problem? If so what was done to fix it.
Thanks, Scott
Old 05-23-2005, 11:03 AM
FLHTCU Rob's Avatar
FLHTCU Rob
FLHTCU Rob is offline
Default RE: '05 FLHRSI Front brake squeal
Lots of posts complaining about this very thing. It happened on my '93, so this is nothing new to HD. Floating rotors seem to do the trick 95% of the time. Good luck!
Old 05-23-2005, 12:10 PM
Grover's Avatar
Grover
Grover is offline
Admin "Kicking The Crap Out Of Spammers"
Take some 200 grit wet or dry sand paper and scrub the rotors in small circles until you get all the way around. This will interupt the grooves in the rotors and kill the squeal.
Old 05-24-2005, 12:02 AM
luvmyflhtcui's Avatar
luvmyflhtcui
luvmyflhtcui is offline
Mine rusted up on my 04 Ultra last winter and the dealer replaced them as they have never seen a bike with 1100 niles on it rust as it did. They are quiet right now and if they start to squeak, I will let you know. Make sure that you wash the bike often to remove any stuff that can build up on the rotors and in the calipers. You might also want to try putting some brake anti-squeel on the piston of the calipers. They also will squeel.
[IMG]local://upfiles/494/5E9597ABA71B4FD1826042D3E2722A65.jpg[/IMG]
Old 05-25-2005, 12:11 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
my front brakes sound like your lettin air out of the front tire.....but no squeel!
JY Kelly
05-09-2022 01:20 PM
dart451
04-07-2016 12:13 PM
Stalkdaddy
04-04-2015 08:59 AM
born4bikn
04-01-2011 10:15 AM
Jett51
03-12-2011 10:57 AM
Quick Reply: '05 FLHRSI Front brake squeal
