Ignition switch problem HELP!!
Old 09-30-2010, 07:59 PM
6023zub's Avatar
6023zub
6023zub is offline
Had the same thing happen on my Road Glide. There is a collar under the switch. The guys at the Dealer told that they had mistakenly reinstalled it upside down or backwards when they adjusted the swing fall away. Not sure if this is your problem, but your post sounded like what I wrote down for the service writer.
Buz
  #32
Old 03-09-2012, 09:41 AM
davep's Avatar
davep
davep is offline
Watched video and made alignment key for aligning keyswitch and works like a charm...Thanks
  #33
Old 12-26-2012, 08:16 PM
bigblue12's Avatar
bigblue12
bigblue12 is offline
2nd Gear
I need so help. I just finished a handlebar install on my 2012 Streetglide. O got everything back together and now my ignition switch will not lock back into place. I watched the video and tried to align my tumbler with a screwdriver, is this wrong? I was able to lock my forks and even turn the switch to run by using a screwdriver. I turned my bars all the way to the left like in the video and locked my forks. I still can't get my ignition key to lock back into place, it just rolls around on the stem. Please HELP!!!
  #34
Old 12-27-2012, 03:50 PM
davep's Avatar
davep
davep is offline
You need to make a alginment tool like the video and it will work......
Rickr01
04-19-2017 09:40 AM
gwphelpss10
06-14-2012 11:36 AM
Gliden
01-02-2012 04:23 PM
citytrucker26
EVO
17
06-15-2010 10:26 AM
scootryder
04-22-2010 04:16 PM
Quick Reply: Ignition switch problem HELP!!
