Twist grip sensor 32310-08: wire colors
just want to say how amazing this knowledge base is here on the site. i am doing both painted inner fairing swap and wo575 swap this weekend. evrything thing is apart. got to the SE tbw sensore only to notice the wires are different colors. was going to post for help, but after a little searching , came up with this great answer, so thank you. now back to my installation.
tin
tin
I could not find this info anywhere, so I am adding it to this thread. For my bar swap I used the TGS from a 2016 softtail part number 32700050 because all the wires including heated grips are in one neat cable with a little connector on the end. The problem was there is no yellow/black color coding to the two sets of black/white/red wires. They instead have one set wrapped with a little blue electrical tape and small blue sharpie dots on the 3 wires in that set. The blue dotted wires are the black set. So they get connected as follows:
pin 1 = black
pin 2 = white
pin 3 = red
pin 4 = black with blue dot
pin 5 = white with blue dot
pin 6 = red with blue dot
The pin numbers are molded into the cap on the back of the plug next to where the wires enter from the back. I got the correct connector (molex 150 6way) and pins from NAMZ, and a cheap molex crimper on ebay (I think it was 40$).
pin 1 = black
pin 2 = white
pin 3 = red
Throttle Grip Sensor Install with Pics
Hi Everyone, thought I would post up some wiring pics of a TGS install I just did (2009 Ultra Classic). Overall, very easy except for the wire color matchups. Hopefully this helps expedite so you can get back on the road. (Don't forget to clear out your codes to ensure your new TGS is going good).
Thank you!
Kevin Pool (03-08-2020)
