Optimal cruising RPM range for a 103 cu inch
Old 07-16-2010, 02:37 PM
TheRainMan's Avatar
TheRainMan
TheRainMan is offline
Default Optimal cruising RPM range for a 103 cu inch
I just picked up a 2010 Ultra Limited and am new to the Harley experience. I'm interested in what seems to be the general consensus on optimal RPM range for cruising with the 103. Thanks in advance for your input.
Old 07-16-2010, 04:22 PM
Spur56's Avatar
Spur56
Spur56 is offline
103 is no different than a 96. If you mean in 6 th, then probably 2500 - 3500 rpm. I usually run 80 @ 3000 rpm on super slab.
Old 07-16-2010, 05:09 PM
KingCripps's Avatar
KingCripps
KingCripps is offline
6400 rpm at about 130. If you want to optimize cruising speed, if you are looking for fuel effieciency, probably something less than that.
(yes, I'm a smartass today.)
tyrant33 (10-14-2016)
Old 07-16-2010, 05:34 PM
2WheelGlider's Avatar
2WheelGlider
2WheelGlider is offline
Ride that bad boy like you stole it! All kidding aside, 2250 to 2750 is where I generally cruise, unless on the interstate in a hurry, then its at 3 or maybe a little more.
Old 07-16-2010, 05:50 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Keep it above 2500 RPM most of the time and shift in 6th after 70+ mph very ideal for your motor.
Hazzardousmat (10-14-2016)
Old 07-16-2010, 09:07 PM
TheRainMan's Avatar
TheRainMan
thanks for the input...
Old 07-16-2010, 09:13 PM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
Agree to that. 2600 in 6th is 70mph 2800 is 75
Old 07-16-2010, 09:16 PM
Ruralmed's Avatar
Ruralmed
Ruralmed is offline
As fast as they will let me go. But, I don't have any fairing or windshield so wind is a limiting factor at times.
Old 07-16-2010, 09:31 PM
Ronp42's Avatar
Ronp42
Ronp42 is offline
Account Retired
I'm hardly ever on the Interstates anymore so 6th gear is not used very much. Riding solo, I try to stay between 2200 and 2800 RPM's. If I'm climbing a hill, I keep it around or above 2500. In your owners manual theres a table of speeds to shift gears up and down. I'm not a hot rodder, I just love to cruise along and listen to that sweet Harley sound
Old 07-16-2010, 09:42 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
At least 2,500
Quick Reply: Optimal cruising RPM range for a 103 cu inch
