Jiffy Stand Spring
Jiffy Stand Spring
While using my Craftsman jack this morning I knocked the spring off the jiffy stand when I let my bike down. Anyway, WHERE does it attach to the frame? I see the spot on the jiffy stand but I can't "feel" anything when I run my hand under the frame where the spring might attach. I wanna go for a ride! Oh yea, 2007 Road King Classic. Help!!
I just had to do the same thing,I found out it is easier to put the spring back on if you have the kickstand in the up posistion. I tied mine up with twine then put the spring into the frame hole and pulled the other end to hole in the tab on the kickstand. I don't even think I had to use a tool. Try that and see how it goes.
Hole in frame, spring has probably got to point down to get it hooked. Stand up, I use a pair of WR-10 vise grips. Easy and cheesie!
Inspect it as it is easily damaged. I've replaced mine twice in the last ten months due to bottoming or catching it on something.
