Installing monkey bars, throttle wire problem
Old 02-06-2011, 06:27 PM
Robert Dennis's Avatar
Robert Dennis
Robert Dennis is offline
Default Installing monkey bars, throttle wire problem
I put a set of 12" monkey bars on my 08 street glide, Does anyone know what color goes to what number on the throttle by wire plug? It didn't have a wiring diagram for it in the instructions. A buddy wrote down the colors but I hope he wrote down the wrong ones because the throttle is not working. The tab broke on the green plug but I taped it up real good and could not pull it apart, so either the green plug came apart or the wires are not in the spot. Thanks Robert
Old 02-06-2011, 06:32 PM
slothy's Avatar
slothy
slothy is offline
let me run out and check mine... and grab my manual
Old 02-06-2011, 06:39 PM
slothy's Avatar
slothy
slothy is offline
black wire is pin 1 (yellow covering)
Attached Thumbnails Installing monkey bars, throttle wire problem-012.jpg   Installing monkey bars, throttle wire problem-014.jpg
Old 02-06-2011, 07:06 PM
bagger76's Avatar
bagger76
bagger76 is offline
looking at my old diagram from when i change to the new one without that green connector. grey #1 purple#2 red3# black#4 blue#5 brown #6 The tab is at number five pin location.Hope it helps if not get back to me i have the sheets on it.
Old 02-06-2011, 09:10 PM
Robert Dennis
Yeah this is the order I have them in, well I guess its the green connector. Can I get the throttle wires out with out talking the bars back off?
Old 02-06-2011, 10:30 PM
Old Bones's Avatar
Old Bones
Old Bones is offline
Here is where the wires go into the plug with the non CVO throttle sensor.
1 gray
2 purple
3 red
4 black
5 blue
6 brown
Old 02-06-2011, 10:38 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
I did the same thing when I changed my bars, thought I had the connector held together good enough even with the tab broken, long story short ended up buying another unit (about $70) I believe, and the dealer had plenty in stock, I wonder why....hmmm.
Old 02-07-2011, 04:43 PM
Robert Dennis
Im going to pull it back out and solder the wires together and do away with the plug first, and if that dont work I guess i'll be off to the dealer. Am I wasting my time or has anyone done this?
Old 02-07-2011, 05:13 PM
slothy's Avatar
slothy
slothy is offline
thats why i spent the 80 bucks and bought the screaming eagle throttle sensor. its all one wire no connector in the middle.
Old 07-19-2013, 11:27 AM
1Harleyrdr's Avatar
1Harleyrdr
1Harleyrdr is offline
I know its a lod thread great information thank you!!
Spindrifter
05-23-2019 08:50 AM
MCRSMedic
02-17-2019 03:34 PM
jamiller85
03-08-2017 09:16 PM
jmoser
09-25-2013 07:31 PM
ms_weasel
Electrical/Lighting/Alarm
12-11-2011 11:39 AM
Quick Reply: Installing monkey bars, throttle wire problem
