velva ride motor mount
I atempted to install the velva ride front mount I bought for my 06 ultra and had a problem trying to remove the old mount. I did as they suggest in the directions and put a bottle jack under the motor to lift it some so you can remove the old and install the new mount. I lifted the motor to the point I was afraid that the gas tank would pop off. I could not get the old one out... so I put everything back together. Anyone done this and have any tricks to get this done?
Thanks
Rick
Thanks
Rick
RE: velva ride motor mount
In order to remove the front mount ( I assume the front lower) You will need to remove regulator bolts & twist it to the side. If you have a oil cooler you may have to loosen it off also. Then support lower part of engine with jack or whatever. Remove the two bolts that hold it to the frame & remove the long center bolt from the top, you may have to (loosen, not totally remove) the mount bracket to the engine to gain enough room to remove the old mount, jack up motor then remove mount. Make sure to center the mount good prior to retightening back. GOOD LUCK
TOOLBOX
[IMG]local://upfiles/11196/DCBA21329AF4490AA8446F8DA6D92B5E.jpg[/IMG]
TOOLBOX
engine mount
Greetings
Gentleman your support is highly recommended
I just bought engine mount lower one V-Thunder velve ride
Unfortunately the technician call me that he couldn't install the part as it's big size and the hall for the nut is little away from the mount 😯😯😯
Any idea to dolve this issue
By the way my bike id HD road king 2005 stage-5 engine
