Broken motor mount ??
Old Jun 25, 2009 | 11:47 PM
1plumr1's Avatar
1plumr1
Default Broken motor mount ??
Front mount on '03 Ultra, are they hard to change?
Old Jun 26, 2009 | 12:15 AM
dawg's Avatar
dawg
Not really. You can undo the bolt and "jack" up the motor and slide out the mount and then reinstall new mount. Just make sure it is put in the right way. The mount can look confusing.
Old Jun 26, 2009 | 04:34 AM
mainshaft's Avatar
mainshaft
Have done a couple, like God I mean DAWG said it's not that hard, do you have the manual?
Old Jun 26, 2009 | 06:39 AM
Road Twister's Avatar
Road Twister
use a small "Bottle" jack to jack the engine up, after you loosen the bolt. I took off the mount to the engine also..made extra working room..very easy...
Old Jun 26, 2009 | 09:18 AM
1plumr1's Avatar
1plumr1
thanks for the replies. I do have a service manual but can't find a nything on motor mounts.
Old Jun 26, 2009 | 10:57 AM
HDRider2002's Avatar
HDRider2002
There is a good write up here, with some pictures to help with the orientation of the new mount. http://www.moccsplace.com/images/mount/mount.htm
Old Jun 26, 2009 | 11:40 AM
Harleypingman's Avatar
Harleypingman
It's been several months since I replaced my front motor mount so I'm not positive about finding information in the '04 HD Service Manual, but I do recall that there is nothing specifically identified regarding R&R of the mount. It may be included in a larger section dealing with engine removal or somthing comparable.
IIRC, I removed the two nuts to get the voltage regulator out of the way after unplugging the electrical connection from the stator.
Then there are three bolts (one from the top and two from the bottom) that attach the mount to the engine/frame.
As mentioned earlier, removing the bolt/nut that attach the top motor mount link makes the job easier.
Not difficult to do at all, just not much information easily accessible in the SM.
Also, I used the "D" version HD mount. It will probably come with a dab of yellow paint on one side; it's that side of the mount that is on the top when installed.
Old Jun 26, 2009 | 01:26 PM
garyhendley's Avatar
garyhendley
great write up and pics too thanks for the info and ride safe
Old Jun 26, 2009 | 06:54 PM
TFTCAR's Avatar
TFTCAR
Smile
Try going to the "glide pro" web page, they have a 20 minute video on changing the front mount under the install heading. you can not go wrong.
Old Jun 27, 2009 | 10:14 AM
1plumr1's Avatar
1plumr1
Once again thanks for the help. The mount will be here Tuesday.
