Touring Pull Back Handlebar Install
Old 06-13-2011, 03:30 PM
red.heritage's Avatar
red.heritage
red.heritage is offline
Default Touring Pull Back Handlebar Install
I am considering installing the above mentioned handlebars on my 2010 Ultra Limited (FLHTK) which is equipped with ABS & heated grips. However, the catalog does not list the bars as fitting the FLHTK.
Have any of you installed these bars on the Limited? If so, are new lower brake lines required (the catalog calls for them on 2009 & later ABS)? Also, is there enough extra length on wires inside the handlebar or are new TBW and grip heating wires required?
Thanks in advance.
Old 06-13-2011, 07:25 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Thanks in advance.
Installed a set on a '10 SG Friday, plus a set on my '09 SG last year...same set up as your limited.....rerouted the clutch cable inside the fairing and adjusted the brake line so it again sits near the handlebars. Loosen the banjo fitting slightly and turn the line until it's where you want it...Plenty of extra wire for the throttle. Not sure on the heated grips but there's probably plenty extra wire for those too....As far as the clutch cable, it's trial & error until you get it just right inside the fairing, using plastic zip ties to secure it so it doesn't rub on other wires near your gauges.......No extra parts needed.....
Old 06-13-2011, 07:31 PM
idontknow's Avatar
idontknow
idontknow is offline
I am in the process now of putting on WO575 on my limited. I didn't need any extensions for the TBW or grips. However, I do need 12" extensions for both the right and left bundles. I have ordered a +4 clutch and +2 upper brake to go with the setup. From the reading I have done this sounds like the correct way to do it. Hope this info helps.
Old 06-14-2011, 09:46 AM
red.heritage
Thanks for the reply. Is the left heated grip glued on? If so, how did you remove it?
Old 06-14-2011, 06:29 PM
jackhis's Avatar
jackhis
jackhis is offline
I'd like to know this step, too.
Old 06-14-2011, 06:42 PM
Chief40al's Avatar
Chief40al
Chief40al is offline
Me too
Old 06-14-2011, 11:25 PM
BLKPRL 09's Avatar
BLKPRL 09
BLKPRL 09 is offline
Stage IV
just a thought...while you are going to tear it down to put on new bars...make sure you mount the ones you want.
I ordered 5 different bars from Dennis Kirk and J&P to try on my '09 SG . Both have no hastle return policy..no restocking fees. It cost me an extra $20 in return shipping but it was worth it....where can you go and sit on 5 bikes set up with different bars
I found that some fit me better than others. I ended up going with the HD, but my friend with 08 ultra decided to go with W1 575s and and my cheapo buddy with a 10 SG went with Khrome Werks Sweepers.
hoggzzer
2014-2023 Touring Models
05-05-2018 07:02 AM
CSTALK0420
12-08-2016 09:19 PM
mike5511
08-05-2015 12:10 AM
shagnasty
02-14-2015 10:41 AM
Chunker
08-28-2011 08:24 PM
Quick Reply: Touring Pull Back Handlebar Install
