SE255 and pushrods
Old 10-28-2011, 05:22 PM
fjoh's Avatar
fjoh
fjoh is offline
Default SE255 and pushrods
Do I need a set of adjustable pushrods alng with the SE255 cams? (My bike is a 2010 SG, stock 96). Or I can just use the stock pushrods?
Old 10-28-2011, 05:41 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
You can use the stock pushrods if you want to lift the tank, pull the rocker boxes, loosen the rockers and pull the OEM rods from the top.
If you use adjustables you can cut the OEM pushrods out with bolt cutters (only) and slip them in between the lifter covers and up into the rockers arms.
If you go with adjustable make sure you get a set that will slip in place without removing the lifter covers (although this in itself is not a big deal), but be wary of the HD tapered adjustables as there have been some issues with the locknuts either breaking or backing off. Many have used these with success but there have been issues...
HD may have addressed this problem but if I used them again I would change the locknuts out for Grade 8 nuts and ditch the OEM nuts.
There are lots of choices of P'rods out there so if you go this route research carefully.
Old 10-28-2011, 09:31 PM
Mick's Avatar
Mick
Mick is offline
The SE255 cams are fine with stock pushrods.
Takes more time to install , but who has problems with stock pushrods?
My personal preference would be to skip the adjustables on my bike.
Just my 2 cents.
Mick
Old 10-28-2011, 09:45 PM
c6z06's Avatar
c6z06
c6z06 is offline
As stated above, the SE 255 work great with the stock pushrods. The cam has the same base circle as the stock cam. I have done both. The first cam change I had was on dyna by the dealer and he left one of the pushrods loose. It was hammering like you know what by the time I got home, 10 miles. The second time I did my own on my 2010 Street Glide using the SE 255 cams and used the original pushrods. I feel safer with these. Agreed, it takes longer and you have to have the cam chest gasket set, but it has everything in it for a cam change.
Old 10-28-2011, 10:35 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
I have done two bikes with 255's and stock pushrods. Works well, and like they said, cannot come out of adjustment.
Old 10-28-2011, 10:50 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
adjustables aren't that bad--- locktite & care are required
save a lot of time on a cam change, leaves that top end intact
Mike
Old 10-28-2011, 11:51 PM
mike5511's Avatar
mike5511
mike5511 is offline
Just my 2 cents.
Mick
Above is what I did as well......no regrets.
Old 10-29-2011, 07:39 AM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
I used the stock pushrods on both of my bikes. The bagger has SE 255 cams, the dyna has the SE 266 cams (has a 120r engine in it). One of the things I like about the stock pushrods is that they will not go out of adjustment.
Some applications require adjustable pushrods, probably due to different base circle dimension on the cam?
Old 10-29-2011, 07:57 AM
Sailrider 1's Avatar
Sailrider 1
Sailrider 1 is offline
As others have noted with the stock pushrods you have NO ADJUSTMENT. This is fine if you don't plan to ride a lot or keep your bike for many miles. With mileage the cam lobes will wear and having a little bit of adjustment capability will allow you to quiet the valve train noise in a high mileage bike. The adjustables work fine with the proper torque on the jam nuts and loctite.
Old 10-29-2011, 08:35 AM
fjoh's Avatar
fjoh
fjoh is offline
thank you for all replies.
I like the fact that the stock pushrods do NOT go out of adjustment as mentioned.
I took a look at my bike's engine and it doesn't have much room between the rear cylinder head and the frame. For those who re-use the stock pushrods, didn't you have problem taking off the rocker cover bolts??
I just don't want to see any surprises after I actually started the swap....
Thanks.
Quick Reply: SE255 and pushrods
