motorcycle ramp
I use a 3 section atv ramp from sams club, $69 rated for about 1200 pounds. I think it about 7.5' long
works fine, it has "rungs" so I cover it with a 1/2 sheet of ply to make smoother for the tires, maybe spreads out the weight a bit.
has flimsy chains to secure to truck, so it doesn't slide back and off the tailgate.
being for atvs it's plenty wide so can walk up beside the bike
mike
mike
Whichever ramp you choose just make sure you tie the front of it to the truck or trailer so it doesnt kick out on you when your rear tire hooks ups. Im sure we've all seen it happen and its usually not a good outcome. Cant help with a brand of ramp but thought id remind you cuz it happens all the time.
I got the 10' Black widow from discountramps.com myself and it's worth every penny. As far as I'm concerned I didn't cheap out on my bike and I'm not going to cheap out on my ramp either. I've only used it once or twice for my bike in five years, but I've used it to put my garden tractor in my truck and many other things. It comes in handy, and even if I don't use it very often I'm glad it's there when I need it instead of trying to "rig" some other bullshit way of getting something into the back of my truck.
I use the Big Boy ll from Discountramps.com. I like this ramp because it's two pieces and each piece folds in half and then both pieces fit in the back seat of my extended cab Ford F250. When I go on trips the ramps are secure and not sitting in the bed of my truck.
http://www.discountramps.com/big-boy...cycle-ramp.htm
Lots of screw-ups loading touring bikes into the beds of pickups. Check out YouTube for some encouraging videos of loading into pickups.
I recommend you spend your money on a trailer with a drop down ramp on the rear. Much safer getting in and out. More tie-down anchor options as well. But each to his own.
I use a black widow from discount ramps. Its 8' long. Works great for me. Wife and I travel 6-7 months a year. Will load bike about 10 to 15 times into a F250. 33" high at the tailgate and I clear undercarriage of bike 95% of the time, unless I'm a little fast ( 5 1/2" ) clearance under my wide glide. 10' would be a better for a lower bike. I did a lot of checking and compairing DON'T GO CHEAP. You will discover your mistake about the 3rd time up.
