The clunk is normal. When sitting at a stop with tranny in neutral, the input shaft of tranny is still spinning. When you pull the clutch in, the shaft will still be spinning due to the slight drag between clutch discs. This drag is mainly caused by the fluid. The input shaft is suddenly engaged with a gear that is not spinning when you shift into first gear. This creates the clunking sound.
mine bangs, or clunks.
to me its just and indicator and I am ready to roll
like someone said, for some reason, it seems ro be one of the idiosyncrasies of a harley
It is the clutch plates not disengaging that is why when you put ATF or synthetic in the primary it is easier to find neutral and the clunk is reduced on a properly adjusted clutch. Mine clunks like hell even on the up shifts and at the first 1000 mile service synthetic is going in.
Bob
