Ignition Switch Plate---Replacement??
Old 09-04-2012, 12:48 PM
B00001's Avatar
B00001
B00001 is offline
Default Ignition Switch Plate---Replacement??
Anyone ever replaced one? PITA?
2009 EG Classic
#11 on this diagram:
http://partsfinder.onlinemicrofiche....D09FLHR074.gif
Old 09-04-2012, 04:30 PM
dawg's Avatar
dawg
dawg is offline
Received 3,014 Likes on 1,735 Posts
The pic shows 11 as a rubber trim piece on the skirt? You asking about that or something on the ignition?
Old 09-04-2012, 04:46 PM
B00001's Avatar
B00001
B00001 is offline
WTH??? Sorry, don't know what happened to my link. I fixed it in original post.
Thank you.
Old 09-04-2012, 05:22 PM
stuart1270's Avatar
stuart1270
stuart1270 is offline
You have to slide it under the black plastic ring # 17 from the front then it snaps into place. There is a slot under #17 when installed correctly.
The diagram shows 17-18-19 below #11 when they actually go on top
Old 09-04-2012, 07:08 PM
StreetGeezer's Avatar
StreetGeezer
StreetGeezer is offline
Yep, that drawing is bogus. #11 is under like stuart1270 said. I've had that thing apart numerous times. The switch comes off easily then 17-19 are just tightened down with a wrench. All pretty easy for a person with standard mechanical abilities.
Old 09-04-2012, 07:37 PM
pontiac69's Avatar
pontiac69
pontiac69 is offline
#11 is real easy to change. i wound up breaking 2 of the tabs that hold it down so i am looking to replace it so it sits flat. i didnt know once #15 is removed that you just unscrew#18 and it all comes off. wonder how much that part is as well as # 14 since mine has 2 dents in it.
Old 09-04-2012, 07:40 PM
B00001's Avatar
B00001
B00001 is offline
The switch I have has a scratch on the ignition plate right where the word "Off" is. So I was going to order this new plate and replace the scratched one.
So the **** (#15) comes off fairly easily once the switch is removed and in hand? So I could replace the plate?
Thanks!
Old 09-04-2012, 07:44 PM
dawg's Avatar
dawg
dawg is offline
Coming off per the manual is easy. If you misalign the tumblers on reinstall, it can **** you off.
Old 09-04-2012, 08:04 PM
StreetGeezer
+1 on this. That's the hardest part of the whole ignition switch removal/reinstallation.
Old 09-04-2012, 08:50 PM
stuart1270's Avatar
stuart1270
Check out this tool. Just got one works great
http://www.marcparnes.com/HarleyIgnitionSwitchTool.htm
Quick Reply: Ignition Switch Plate---Replacement??
