Exhaust problem v. bracket issue
Alright, spent the day screwing around with getting my broken exhaust off and fitting up the new. Got the front cyl. done and thought the rear would be simple...wrong. There's a triangle shaped support bracket that the stock header was attached to, but the new rear head pipe is hitting the bracket and not letting it fit up to the head.
he header Im using is off a '98 Roadking, my bike is an 01 Electra Glide. From everything I've read it should fit, but Im guessing the support bracket is supposed to be in a different place because of the slightly different routing of the exhaust?
Anyone got some insight on this?
Here's a couple pics of it:
the only attachment to the frame is the rubber isolated mount under the saddlebags
here is a diagram of the stock system:
http://partsfinder.onlinemicrofiche....EXHAUST-SYSTEM
since you are going to an aftermarket style, you, will have to adapt a mount for the rear header.
you may be able to fab a mount to replace the "triangle"- but you need something there.
or grind some clearance
Or you could crease the pipe there to get some clearance- not a 1st choice though...
mike
nope the exhaust needs to be supported BY the drivetrain--- because the whole thing has to "float" together.
mike
mike
Looking through that link, it seems they only show one exhaust system for pretty much every bike. Like I said in my original post, my new header pipes are a true dual design (no cross over pipe) that are supposed to be factory from a '98 Road King.
