Load Equalizer Question
Old 01-23-2013, 06:00 PM
rebbe18's Avatar
rebbe18
rebbe18 is offline
Default Load Equalizer Question
On a 2012 EGlide, I have the following set-up:
LED rear signal bulbs
Harley Run/Brake/Turn module
Harley Conversion Kit making the tour pak lights brake/turn/running lights
No load equalizer as the front signal bulbs and tour pak bulbs are regular bulbs
Here is the question:
If I change the front signal bulbs to LED and leave the tour pak bulbs as regular bulbs, will the draw from the tour pak bulbs allow me to not require a load equalizer since they are regular bulbs and now act as signal lights?
Before I spend $55 on a Biketronics Load Equalizer, I wanted to be sure I needed it.
Old 01-23-2013, 06:09 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
I have LED signals all around on my 2004 Road King, the only load equalizer I have is for the rear signals, none needed for the fronts. All LED's are from Custom Dynamics, the LED bulb in the TL is from "across the ocean" but still seems to work well.
Old 01-24-2013, 12:53 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I installed LED blinkers and they wouldn't work without a load equaliser. They are fine with one - I bought a Badlands. I tried without one first, then bought one! You may have to do the same....
01XLH
2014-2023 Touring Models
02-11-2016 07:47 PM
jgcable
05-20-2010 10:22 PM
rebbe18
04-29-2010 08:50 PM
larry5h
02-27-2007 10:19 AM
Mike1397
08-20-2006 06:56 PM
Quick Reply: Load Equalizer Question
