lighting question
Old Feb 12, 2007 | 10:58 AM
larry5h's Avatar
larry5h
Default lighting question
Is there a kit available to make the lights in the tour pak work as turn signals also?
Old Feb 12, 2007 | 11:15 AM
Keystone's Avatar
Keystone
Default RE: lighting question
You mean like this?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Feb 12, 2007 | 05:47 PM
larry5h's Avatar
larry5h
No,I have a 06 ultra that already has the tour pak lights,but they only work as brake and running lights. I would like to add the turn signal feature also.
Old Feb 12, 2007 | 07:12 PM
FLGEEZ's Avatar
FLGEEZ
If you were to put in a Run/Brake/Turn signalcontroller, one that operates a single contact bulb or led on your lollipops, and ran a pair of wires from each lollipop to your respective tour pack lights, and then replaced the dual contact sockets with single contact sockets, like your lollipops, and put in 1156 or equiv bulbs or led.... Then if no load balance was necessary for your turn signal controller...
Lot of 'maybe' work, but electrically it can be done.
Old Feb 12, 2007 | 08:09 PM
Bryan TTM's Avatar
Bryan TTM
yes...i orderedtwo 12" LED strips(one to replace the lights on each side)from Custom Dynamics and also 2dual circuit elements....those will allow you to have run/brake or run/turn....just find the turn signal wire and splice into it
http://customdynamics.com/flex_led_array.htm
Old Feb 12, 2007 | 08:19 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
ORIGINAL: Bryan TTM
That looks pretty cool, do you have any pic's of the installation?
Old Feb 12, 2007 | 08:30 PM
Bryan TTM's Avatar
Bryan TTM
have all the parts and have fitted them...tour pak went to paint today with my bags and side covers...only thing left is the assembly and locatin appropriate harness's and wirin it up....but there will be pics with full explanation and the all important
DONT DO THIS
Old Feb 13, 2007 | 02:32 AM
FLGEEZ's Avatar
FLGEEZ
ORIGINAL: larry5h
Larry,
Am I missing something here? Do you want your TP lightbar run/brake lights to become 3 function, run/brake/signal?
Or are you talking about the side marker lights on the Tour Pack?
Old Feb 13, 2007 | 12:03 PM
larry5h's Avatar
larry5h
I have the run/ brake/ turn harness installed but the lights on the tour pak only function as run, stop. I would like to add turn
signals to the tour pak.
Old Feb 13, 2007 | 07:22 PM
FLGEEZ's Avatar
FLGEEZ
I don't know which controller you have, but the concept applies to any single pin, 1156 typelight. You can route the same electrical path from your run controller that services each rear light to your Tour Pack lights. They will have to be single pin sockets and bulbs, just like the lollipops. Warning. I don't know if your controller will carry the load. I wouldrun a load test and jumper in an addition set of single 1156 or equiv of your lollipops before I cut the dual leads in the TP. You may toast the controller. An Alternative would be to by a separate controller and run the TP ( w/ new single contact bulbs) off of it.
Now comes the 'Idiot Disclaimer'.
I had on an 'Amber/ClearAux light' threadstated the amber may not be legal in 'your' area and spoken about Virginia incorrectly. I don't know why HD did not emulate a system that Off Shore manufacturers use that makes a GoldWing look like the 4th of July when stopping or turning. May be a reason. Dunno. On my wife'sTrike I wired in a Smart controller to give her Flashing Brake lights, but alas no signals. It adds attention getting Lumens. Her turns are still amber and far enough away from the TP.
Here is why I want more flash for hers. It was the Billings buster
[IMG]local://upfiles/17522/F4C8822407CE4A45919FC8AF4A7A7735.jpg[/IMG]
