Two questions for FM build
I will be receiving my FM107 kit this week and have two questions regarding replacement parts.
I'm installing the LMR pressure relief spring to bump the oil pressure. Does the roll pin holding the spring in need to be replaced or can I just reuse the old one?
Same question for the front cam snap ring. Does that need to be replaced as well or will the original one be fine?
I hate going to the dealer and spending $25 for two pieces of metal that cost about $.20 to produce. Thanks in advance.
that said, i reused the rollpin the first time i swapped springs becuase i forgot to get them. now, i have a lot of them in the shop
snap ring is worth replacing
Thanks for the input. I broke down and just bought two new pieces. Better safe than sorry. It was actually less painful than I thought. $3.90 for both pieces. Not too bad considering I purchased that from a dealership.
