Push Rod Leaking After Cam Install
Old Mar 10, 2018 | 03:59 PM
lhgdale's Avatar
lhgdale
Default Push Rod Leaking After Cam Install
Hello, I'm having issues getting my push rod tubes to seal up. I did a cam swap on my 18 Road Glide Special and the only issue is the exhaust push rod tubes leak oil. I did order the black push rod tubes from Harley to replace the stock chrome ones. I am going to try stretching the springs a little and see if that helps. I'd appreciate any tips or tricks you guys have. Bike runs awesome by the way. Thanks
Old Mar 10, 2018 | 04:32 PM
rdc401's Avatar
rdc401
Make sure you have the o rings in all the way,roll them around with your finger.
Most of the time that is the problem,and you may have to replace that o ring that is leaking,may have cut it when you put the clip in.
ive had a couple that leaked and that was the problem with all of them
Old Mar 10, 2018 | 04:57 PM
$tonecold's Avatar
$tonecold
You didn’t say where on the pushrod tubes the leaks are. It’s hard to diagnose anything without seeing it, but a good description helps and pictures are even better. I think many would be glad to help, but more information is needed.
Old Mar 10, 2018 | 06:11 PM
lhgdale's Avatar
lhgdale
It appears to be the top O ring that is leaking the most, maybe a little from the middle o ring. I plan on taking it apart and checking. There is not much spring pressure with these new pushrods. I can put the clip in using my fingers.
Old Mar 10, 2018 | 07:18 PM
pittz5's Avatar
pittz5
i just went through this same thing. When I pulled the top oring I could see where the tube caught the o-ring and cut it when I put it back in. Grrrrrr, Leaked all over on my test ride. Also a good idea to coat the new orings with oil too. Good luck.
Old Mar 10, 2018 | 08:56 PM
VDeuce's Avatar
VDeuce
Probably nicked the o-ring at the head. Here's a quickie fix and if it doesn't work, then disassemble and replace...
Pop the clip off, back the tube down, clean using brake parts cleaner. Use a small dab of high temp black RTV and apply using an applicator to the top horizontal ledge of the tube around its circumference and insert the tube into the top o-ring. Allow RTV to setup. It may very well solve your problem; ask me how I know .
If that doesn't work, take it apart and do it the right way lol.
Do not alter the spring - it is not the problem.
Old Mar 10, 2018 | 10:39 PM
lhgdale's Avatar
lhgdale
Thanks for the tip. I'll give it a try tomorrow and see if that helps.
Old Mar 12, 2018 | 04:47 PM
lhgdale's Avatar
lhgdale
I disassembled the push rod tubes last night and wiped down the o-rings really well. I did not see any obvious tears or cuts. Reassembled everything and double checked the o rings were seated correctly. I started the bike, let it warm up, revved it a few times and no visible leaks. My fingers are crossed that I fixed it.
Old Dec 14, 2018 | 07:58 AM
Bryan82's Avatar
Bryan82
Have you been leak free? Ever since I installed my S&S 475 cam, I've had leaky pushrod tubes in the rear cylinder. I have found anywhere from small nicks up up gouges out of my upper tube orings. Only on the inside diameter of the oring though . I can't figure out how the heck this keeps happening so consistently. I even checked the clearance of the rocker arm cradle to the pushrod orifice in the head.. seems good though .
Old Dec 14, 2018 | 08:55 AM
sixguns's Avatar
sixguns
I engage the upper tube first, and hold it in place while pulling the lower tube down and snapping it into the lower O-Ring, never a problem doing it that way.
