Second try to find electrical issue.
Old 04-23-2013, 06:34 PM
02Ultra EG's Avatar
02Ultra EG
02Ultra EG is offline
Angry Second try to find electrical issue.
Well, going to give this another shot. Last summer while riding had the bike quit after blowing an ignition fuse. Did some roadside trouble shooting and got the bike to run another 3 miles. Parked bike and got truck to haul home. Checked out some pinched wires in the Rt. handle. Thought that might be it. Not! I could put in new 15 amp fuse an d run for 10-15 miles and boom, blown fuse. Replace the fuse and blows again. Let the bike sit for 45 min. and replace fuse. Bike starts up and runs again for 10-15 miles then blows fuse again. Just before it blows I notice a slight misfire. Took it to the dealer and explained to service tech the problem. After they had the bike for a week, they said they could not find any problems. I asked if they had ran the bike, they said just in the shop. I asked them to put it on the dyno and run it with a load. Checked back 3 days later and they said they ran it 50 miles on the dyno and road it 20 miles with no problem. They then charged me $100.00 for all the work they did. Now I have an issue with what they say they did. $100.00 for 10 days in the shop, 1 hour on the dyno and all the time spent trouble shooting. Am I missing something? I asked them what I might be able to do to figure this out. Don't want to be making a left turn in traffic and have it die. The service Manager said he had a guy who had a front fender light that was shorting out and blowing the ignition fuse?????? I think something is getting hot and then overamping and blowing the fuse. Like I said, if you let it sit the fuse will be ok and the bike will run for a short period of time. I hate to start changing out componets but need to get it fixed. Wife is driving me crazy wanting to go for a ride! Where can I start?
Old 04-23-2013, 06:38 PM
davidwruth's Avatar
davidwruth
davidwruth is offline
Possible wiring around motor when it gets hot and expands and possibly shorts a wire? Just a thought
Old 04-23-2013, 06:39 PM
davidwruth's Avatar
davidwruth
Have a lot of questions. How is it sitting when it blows fuse. Do you have to be riding it or not. Do you do anything right before it Blows the fuse?
Old 04-23-2013, 07:07 PM
ultra purple's Avatar
ultra purple
ultra purple is offline
How handy are with a dvom. It sounds like you MIGHT have a wire hanging on by one strand, or corrosion in a connector. If you do a LOADED volt test it will show you a weakness compared to a volt test. In other words you can be getting great voltage but not supplying amps. This will cause it to act like this as well.
Old 04-23-2013, 07:12 PM
pastime's Avatar
pastime
pastime is offline
Great advice.
Just curious....were you upset with the $100 the dealer charged you? Sounds like they put lots of hours in the troubleshooting and only charged you for about an hour or so. IMO they didn't rip you off, sounds like they were sympathetic and tried to be fair.
Old 04-23-2013, 07:14 PM
dawg's Avatar
dawg
dawg is offline
Received 3,014 Likes on 1,735 Posts
Check the three wires as it enters the back of the ignition switch
Old 04-23-2013, 07:24 PM
dawg's Avatar
dawg
dawg is offline
Also check the wire loom as it crosses the fairing bracket. Has a tendency to rub through and short out.
Old 04-23-2013, 07:29 PM
elfnyc's Avatar
elfnyc
elfnyc is offline
do u have a cig lighter ?
Old 04-23-2013, 08:42 PM
RIDERED67's Avatar
RIDERED67
RIDERED67 is offline
50 miles on a dyno???? Really?
Old 04-24-2013, 08:00 AM
02Ultra EG's Avatar
02Ultra EG
Ok, the fault occurs while riding down the road. A few times the motor has a slight hesitayion just before quitting. Makes me believe something like a coil might be over amping. I pull to the side of the road, park the bike, pull the side cover to replace the fuse and it pops another fuse. If I let the bike sit without moving it at all for 45 min put a new fuse in, it fires right up. Have started to check for worn wires and bad grounds.
Quick Reply: Second try to find electrical issue.
