where is the?
where is the?
My ultra does not have the security key fobs, I want to know if it still has the hardware intact but don't know where to look.
If its still on it, I'll get some fobs from the dealer. The manual doesn't show the location(maybe I'm looking in the wrong place), anyone know where it is?
Came this way from original owner who likely pitched the fobs after having the dealer change the security codes so it wasn't needed.
Thanks
Thanks
Thanks
Thanks
I used to have the TSSM (Turn Signal and Security Module) which went bad, so I replaced it with a TSM (Turn Signal Module, No Security). They re-flash the chip at the dealership and no more red security key.
Still have the fob on the key ring, but is doesn't do anything anymore. Getting a FOB if you only have a TSM wont do anything, you have to get the TSSM if you want to go with a fob, and it is PITA. Just forget about a fob if you dont already have one.
I don't think you can...
I don't think you can disable the Smart Security through the programming.
If this is a Smart Security system that is! If it not, sorry, please ignore.
If the previous owner had Security and got rid of it, he probably swapped out the TSSM for a standard TSM.
The Smart Security is the Turn Signal Module. If you have the Smart Security, it's called a Turn Signal Security Module or TSSM, if you don't, it's called a TSM.
Yes, it's under the right side cover.
Good luck!
GSF
Good luck!
GSF
voodoo73
08-13-2014 06:19 AM
Mr Bentwrench
02-03-2014 11:26 PM
justmealwatts
04-06-2013 12:28 PM
