Speaker question...............................
Old 07-18-2013, 12:03 PM
mwriggs's Avatar
mwriggs
mwriggs is offline
Default Speaker question...............................
Best Buy has their Polk-Audio 6 1/2" speakers on sale for $39.99, and mine are pretty worn. I already have the adapter ring, but my question is if I buy those Polk_Audio's could I use bubble wrap for packing to push the sound forward???? Figured it wouldnt matter if moisture got to it.
Old 07-18-2013, 12:08 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
bubble wrap?
I'd suggest that it wouldn't do anything and the packing in a speaker cab is to control resonances--- not "push the sound forward"
if you are worried about moisture and paper speaker cones, speakers can be scotch guarded.
mike
Old 07-18-2013, 12:21 PM
mwriggs's Avatar
mwriggs
mwriggs is offline
Ok I didnt know that is what the packing is for. These speakers have poly cones, so moisture shouldnt be an issue.
Old 07-18-2013, 12:51 PM
acchd's Avatar
acchd
acchd is offline
If your installing these to a stock Hardon Kardon headunit be sure the Polk Speakers are 2 ohms impedance. If it's Polk db651's there 4 ohms. Some wrap there speakers with Polyfil for improved sound.
Old 07-18-2013, 12:53 PM
UltraWalt's Avatar
UltraWalt
UltraWalt is offline
Go to Walmart where the pillows are and get a bag of poly fill it will send the sound to you with a much proved sound quality
Old 07-18-2013, 01:11 PM
Frank Dukes's Avatar
Frank Dukes
Frank Dukes is offline
looked them up - they are 4 ohm speakers.
http://www.bestbuy.com/site/Polk-Aud...specifications
Old 07-18-2013, 01:19 PM
vickers1's Avatar
vickers1
vickers1 is offline
Don't buy 4 ohm speakers unless you are riding an '05 or earlier. Your radio is set up for 2 ohm speakers.
Old 07-18-2013, 01:25 PM
mwriggs's Avatar
mwriggs
mwriggs is offline
Mines an '06, so I guess those wont work with the stock HK head unit. What are most headunits now a days?
Old 07-18-2013, 01:51 PM
acchd's Avatar
acchd
acchd is offline
If your looking for low cost 6.5" replacement speaker for your HK the Infinity Kappa 62.9i is a 6.5" speaker that is 2 ohms that'll work. I've seen them in $70 range online. They'll sound a lot better than stockers.
Old 07-18-2013, 05:16 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Infinity and JBL both have good 6.5" coax 2 ohm speakers. They are good matches for the stock HK head unit as they are made/owned by Harmond Kardon.
Quick Reply: Speaker question...............................
