Not the starter I think
Had earlier post about bike not starting at times. It would start run to store then wouldn't start when I come out. After checking my grounds and terminals still no good. Thinking time for new starter. Buddy comes over toys with neg terminal on battery started great. Ran great started couple then nothing. So I go back in moved ECM boom started. Ran pulled in no start. Moved ECM again started. Seems like if I reposition the ECM bike starts up. But then nothing. Thinking loose connection any ideas how I should handle it.
Thanks guys appreciate the help
year/model?
regardless of year/model when you have a no start- check to see if you have voltage to the solenoid ( little green wire), when you push the starter button.
that will tell us if the fault is in the primary starter system( switches, relay, wiring), or the secondary (starter, solenoid, battery cables)
mike
mike
Robert Evans
03-27-2012 10:43 AM
