Bikes with Harley oil coolers
Old 10-15-2013, 03:10 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Default Bikes with Harley oil coolers
Do you guys with Harley oil coolers either added or those that came stock on their bike, end up adding more than the recommended 3.5 quarts of oil during a change? This will be my first change since adding the cooler and initially when I added the cooler, it took some additional oil to top off the tank. However, now I'm thinking that short of pulling the cooler and hoses the cooler will remain filled with oil during the change and I'll still need only the standard 3.5 quarts? I pulled the drain plugs on all 3 holes while oil was nice and hot when I came home from my last ride of the season Last Saturday. I need to pick up oil on the way home tonight and will only need to pick up 3 quarts if this is the case. I have 1/2 Quart left from previous change. And Yes, I realize that the oil left in the cooler is old. So is the bit left in the cases etc. Thanks
Old 10-15-2013, 03:16 PM
sfchief's Avatar
sfchief
sfchief is offline
No additional oil during change. As you guessed, the oil seems to stay in the cooler and hoses.
Old 10-15-2013, 03:25 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Scrmnvtwins is offline
My '03 I added a cooler when new, never changed the oil in the cooler
My 13 came with an oil cooler and getting ready for 2nd oil change and I will not be changing the oil in the cooler
Use Dino oil in both and fill as necessary to get level up between marks on dipstick
Old 10-15-2013, 03:29 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Thanks guys! Saved me buying another quart until spring 2014! Stuffs not cheap! lol
Old 10-15-2013, 03:31 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
WARDSPARTSWERKS is offline
I always pull the hoses at the cooler adapter and hit the upper port hose with a little low pressure air to blow all the old oil out the lower port. Not really necessary but I like to clean out the 8-10 oz of dirty oil in the heat exchanger and lines, there is already a good bit of residual dirty oil left in the engine, then 4 qts puts me right at full.
Old 10-15-2013, 05:12 PM
bent trix's Avatar
bent trix
bent trix is offline
I leave the drain plug out, turn on the key and turn off the ignition (so it wont start) Then crank it about 3 rotations, it will pump most of that old oil out of the system.
Old 10-15-2013, 05:27 PM
C.H.L.'s Avatar
C.H.L.
C.H.L. is offline
I think the oil colors came stock on the 103 models in 2012.... maye CVOs and stuff before then, but not sure - I know the 103s and 110s have been options or a while, but when the bikes started coming with them in '12, i think is when the oil color was standard.
Old 10-15-2013, 08:13 PM
asahi1234's Avatar
asahi1234
asahi1234 is offline
103 came out in 2011 I have 2011 RKC and it had oil cooler from factory.
Old 10-15-2013, 09:03 PM
Cosmic Charlie's Avatar
Cosmic Charlie
Cosmic Charlie is offline
Not sure about that procedure - mine won't spin when the handle bar switch is OFF - if thats what you meant ...
My oil cooler is left alone during oil changes - lets the old oil more easily become friends with the new oil !
Old 10-15-2013, 09:22 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
Huh??
Ohiobellboy
Oil Archive (no new posts)
09-04-2018 10:06 PM
Knuckles73
11-13-2014 12:09 PM
sportyfan
01-25-2013 05:00 PM
JJHOG
03-08-2012 01:43 PM
leeinmemphis
08-24-2009 10:04 PM
Quick Reply: Bikes with Harley oil coolers
