problems after exhaust install
Old 01-27-2014, 01:04 AM
toddhowudoing's Avatar
toddhowudoing
toddhowudoing is offline
Default problems after exhaust install
I have a 2013 streetglide it has a stage one a/c and download.I put a set of 4 rhinehart slip-ons on over the weekend now it idles at about 1200 and smells like its running rich as hell. I torqued the muffler clamp bolts to 55 pounds. Also tried disconnecting battery and it is not throwing any codes. Does this sound like a tune issue or possible exhaust leak?
Old 01-27-2014, 01:38 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
idle at 1200 would be normal for a cold machine, and also an overly rich mixture until the motor is warmed up.
you can check for exhaust leaks with the smoke from the tip of a cigarette.
I bet you are ok though...just let it warm up all the way
mike
Old 01-27-2014, 04:53 AM
Geezer glider's Avatar
Geezer glider
Geezer glider is offline
Exhaust leak would likely create a lean condition. Take it for a ride to see if it's running correctly. You don't say if you still have the factory header or if you have a tuner. You can change the mufflers, but if you changed the AC also,then you should get a tuner.
Old 01-27-2014, 05:00 AM
tcatman02's Avatar
tcatman02
tcatman02 is offline
he said he has a stage 1 AC and download
Old 01-27-2014, 06:19 AM
RebelBugler's Avatar
RebelBugler
RebelBugler is offline
How does it perform when you ride it? More power, less power, popping?
When cold, they all run rich. You mentioned a download....do you have a fuel system installed or is it the H-D download?
Old 01-27-2014, 11:53 AM
toddhowudoing
Its the HD download, I rode it about 60 miles since install still have a high idle and running rich. Runs fine and had good power
Old 01-27-2014, 02:00 PM
jdvorchak's Avatar
jdvorchak
jdvorchak is offline
Was that 60 miles at one time? Or 30 trips of 2 miles each? High idle and rich are indications of a cold engine.
smithbrl's Avatar
smithbrl
smithbrl is offline
Did you try the "cycle the ignition on and off 3 times" trick?
Old 01-27-2014, 02:10 PM
toddhowudoing
about 2 seperate 30 mile trips and yes I did try the ignition cycle trip, it was about 40 degrees out. Soon as it warms up a bit ill get it out and take a nice long ride.
Old 01-27-2014, 02:39 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Should be under warrenty. The slip-ons aren't your problem
Quick Reply: problems after exhaust install
