Wheel/Tire Size
Old 02-02-2014, 09:30 PM
2008GLIDE's Avatar
2008GLIDE
2008GLIDE is offline
Default Wheel/Tire Size
What is the largest wheel/Tire combo width you can run on a 2008 Street glide? Stock is a130 on a 3.5"wheel I think.
Old 02-02-2014, 09:57 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
On the rear is an 18x4.25 with a 150/70/18, on the front without changes a 21x3.5.
Old 02-02-2014, 10:00 PM
2008GLIDE's Avatar
2008GLIDE
Thanks for the reply. Is a 4.25"width wheel common?
Old 02-03-2014, 11:29 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Some Harley models have 4.5" wide rims, but 4.25" is a common aftermarket width (check Hogpro's website!).
Your stock wheels are both 3" wide AFAIK and the limits on the rear wheel width are internal fender width and clearance between tyre and belt. A 150mm tyre will go in, but any wider requires surgery!
Old 02-03-2014, 05:12 PM
2008GLIDE's Avatar
2008GLIDE
Good info. I do have to ask..... What kind of surgery?
Old 02-03-2014, 05:33 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
18x4.25 is a wheel size made by all major wheel manufacturers, yes it is a very common size.
Old 02-03-2014, 06:00 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
u can get a 160 e3 on it BUT...that tire is made for a 3.5 inch wheel,your stock 3 inch wheel pulls in the sidewalls just enough to fit,it may require a tiny belt guard trim.
Old 02-03-2014, 06:26 PM
2008GLIDE's Avatar
2008GLIDE
Good Info!! Is that the size u run? What is the rest of the size 160x?x?
Old 02-03-2014, 06:53 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
I won't mount a 160 on a 3 or 3.5" rim and i think the 160 is too wide for that bagger.
Old 02-03-2014, 07:28 PM
bigdumbnoitall00
I wont run a 160 either (mu90 now) but it will fit,just hope it stays on the wheel if u get a flat.
Quick Reply: Wheel/Tire Size
