Wanted to order the J&M 7.25 speaker upgrade for my 05 electra but it starts at 06?
what others are just as good for my 2005. thank you
http://www.jmcorp.com/ProductDetail....D=HCSK-7252GTM
Or you can add an amp and then put whatever speakers in there you want.
the difference between 05 and 06 is the ohm of the speakers themselves. If you're running a stock head unit from an 05, then you'll need to stick with a speaker setup that accommodates the 8 ohm load of the head unit. 06 is when HD started using the HK head units vs the Radio Sound head units previously and the 06 and up are 2 ohm head units.
If you're asking me what I would do;
then yes I would add something like a RF PBR300x2 and a good pair of 6.5" speakers up front. There are a ton of speakers that are good matches for both the bike and that amp. It all comes down to what you want to spend. If you want to do it right once, then the PBR300x2 and a pair of Biketronics 7.1" speakers for the fairing and be done with it.
