5th gear chatter - need your opinions
2010 FLHTC - 24,000 miles Redline in tranny and Syn3 in the other holes.
I've read alot of posts about 5th gear noises. Mine has been noise free since I replaced the Inner Primary Bearing late last summer (1500 miles ago). While having the bearing job done, I opted for the SE Clutch Spring and SE Compensator.
Since the repairs, I have a strange chattering coming from the left side of the bike and seems like from my left foot area. The noise will only happen when the bike is well warmed up in 5th gear, and only when in 5th gear with cruise control set at about 60 mph - 27-2800 rpm, and only when slight load is placed on the driveline. While on cruise-control, if the noise starts chattering, it will immediate stop chattering when I apply some throttle.
Why, after having 22500 pleasurable miles with quiet cruising would such a chattering noise begin under low-load cruising situations? It was to be related to 5th gear, but it's the same 5th gear that was there before the repairs!!!
Please help.
Please help.
2010 has a differently cut 5th gear than all other years.
this is likely the cause of your concern. HD changed back to the 09 and earlier for 2011+, so your can't compare to bikes other than 2010
you can see that the 5th gear on the 2010 is helical cut, that makes for quieter operation, but 5th is less strong than a straight cut gear- and has more "side loading", torsional load placed on the shafts, cases and bearings.
I am guessing that in 5th, your tranny mainshaft is being pushed out of place
traditionally HD trannys the gear 2nd from top is straight cut- 2010 is the only one different that I know of.
useless trivia, but the Rider's Handbook for my 1953 reminds the Rider to use 4th gear for cruising and to always use 3rd to pass or go up a hill as 4th isn't strong enough
mike
mike
mike
Hey, thanks Mike. That's a great diagram, and I knew 2010 was different than 2009 and earlier trannies, but didn't know that in the 2011 and later models they went back to the 2009 model.
What I'm really struggling with is why the bike made absolutely no noise for the first 2500 miles, and now it just starts doing it.
I've read about drive-belt tension, rear IDS pulley, compensator bolt torque, primary chain tension, belt guard clearance - but can't get past the work that was done on the IPB, clutch spring and compensator.
Do you still have the little rubber bumper on your kickstand?I lost mine awhile ago and it would rattle loudly every once in awhile.Only seemed to happen after the bike was warmed up and at a certain RPM.I thought I had primary issues before I realized what it really was.
I'm pretty sure 2010+ are all Helical Cut gears for 5th, not just 2010.
Two reasons:
1. It was not mentioned in the 2011 Technical Forum.
2. There is no longer 5 million daily posts about gear whine like there was in 07, 08, and 09.
OP, it's probably your Comp... Chattering is not gear whine. Whine sounds like a supercharger or bearing going bad.
lp
Two reasons:
lp
