Turn Signal a blink fast after 5 blinks
Old 07-27-2014, 07:12 AM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Default Turn Signal a blink fast after 5 blinks
Here is the scenario. Had a trailer hooked up for a couple of days while on a trip. Everything worked fine. All lights worked as they should. Now once the trailer is unhooked the turn signals start this fast blink after a few regular blinks. Any ideas why and how to get them to blink normal and not fast. All bulbs are working, it is acting as you have a light out but I don't.
Old 07-27-2014, 07:25 AM
Reaper22's Avatar
Reaper22
Reaper22 is offline
Mine will do that from time to time because of moisture and corrosion due to washing, Just means one turn signal is not working, just clean contacts and grease..
Old 07-27-2014, 07:30 AM
chopswalton's Avatar
chopswalton
chopswalton is offline
I have friend just ask me if I ever had this same problem when Unhooked my trailer in the pass. I have a load protector in line on trailer harness so I don't. I understand when you unhook your trailer it telling you bike it has a bad bulb. I read the service manual for an 08 says turn ignition off and then on turn on left signal for four or more flashes then do the same for the right should clear code. I don't know if that will take care of the problem but give it a try.
Old 07-27-2014, 08:57 PM
jimartina's Avatar
jimartina
jimartina is offline
I had a bad front bulb that was working, but was causing fast flash. I could see that the element was not in new condition anymore. so i changed and they started working properly.
Old 07-28-2014, 08:09 AM
SpiderPig's Avatar
SpiderPig
Thanks, this worked.
kmj
EVO
05-15-2017 02:04 PM
MontyCop05
05-12-2014 09:02 AM
jbhawley
05-15-2008 06:42 AM
jfbrown
01-29-2008 10:25 PM
donaldrj
01-30-2006 11:05 AM
Quick Reply: Turn Signal a blink fast after 5 blinks
