1990 electra glide classic
Old May 13, 2017 | 08:37 AM
kmj's Avatar
kmj
Stage III
Default 1990 electra glide classic
when i turn on the left turn signal the right one blinks dimly also . When i push the button for the right turn signal to come on nothing happens at all . Any help would be appreciated thanks
Old May 15, 2017 | 08:46 AM
richard567's Avatar
richard567
get a badlands signal modulator...
Old May 15, 2017 | 11:31 AM
0maha's Avatar
0maha
Might be a bad module, but from what you describe, my money is on you having a short to ground somewhere on the "hot" side of your right turn signal circuit.
What you need here is a wiring diagram, a multi-meter, a six pack and an afternoon to spend chasing that circuit.
Old May 15, 2017 | 02:04 PM
yellowstone kelly's Avatar
yellowstone kelly
Classic symptom of a missing or poor ground connection somewhere.
Same exact thing happens often when hooking up a trailer to a tow vehicle. Activate one of the turn signals, and if the ground circuit between the vehicle and the trailer isn't good enough, every light on the trailer will blink a little. A quick test for that is to grab a set of jumper cables and connect one end to a good ground on the tow vehicle and the other end to a good ground on the trailer, and like magic, only the correct light blinks on the trailer.
So if I was troubleshooting this problem on a bike, I'd make up a few 4-ft to 6-ft long wires with alligator clips on each end and temporarily "add" them as ground connections to each component of the turn signal circuits so that I knew for sure everything had a good ground.
Bad grounds always seem to cause strange symptoms that make no sense.
I second Omaha's advice regarding the wiring diagram, beer, and plenty of time to work through this.
MudFlap379
Electrical/Lighting/Alarm
Aug 12, 2014 10:40 PM
SpiderPig
Jul 28, 2014 08:09 AM
MontyCop05
May 12, 2014 09:02 AM
jbhawley
May 15, 2008 06:42 AM
jfbrown
Jan 29, 2008 10:25 PM
