31t trans pulley
Old 09-07-2014, 06:55 AM
Srx gpx's Avatar
Srx gpx
Srx gpx is offline
6th Gear
Default 31t trans pulley
Just wondering from the people that have put the 30 or 31t trans pulley on, how much does it increase RPM? I would like to increase mine about 200rpm. Bike is a 2013 street glide
Old 09-07-2014, 10:00 AM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
The 30 tooth will increase your rpms by 300.
2010 Limited with some stuff
Old 09-07-2014, 10:08 AM
Bobs67ss's Avatar
Bobs67ss
Bobs67ss is offline
6th Gear
I went from 32t to 30t on my 2010trike and it made a huge difference. Had a TTS at the time so redoing speedo was no big deal. used a trike 30t from Harley that cost $68 brand new seems that 70mph was around 3000rpm ,but was a trike so back tires may have made a difference
go to Andrews site and view catalog pages for gear ratios
thinking of this also,31t able to use stock belt....2014limited
I never use 6th unless doing over 65mph and has no effect on my mileage getting 43mpg going 2 up on 2014
Old 09-07-2014, 10:32 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
It's easy to work out for yourself. Make a note of the rpms at your chosen road speed, then simply multiply by 32/31 or 32/30 to give you the revs for 31T and 30T respectively. At 2,500rpm your new rpms will become 2,580rpm or 2,667rpm. Frankly a change of only one tooth isn't worth the trouble and expense.
Old 09-07-2014, 12:25 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
It is worth it if going 2 teeth on the trans pulley requires a belt change to a non-oem belt that is prone to failure. I changed my 66t rear to a 68t rear which is equal to 1 tooth on the trans pulley and it was worth it. A 6speed bikes gearing sucks so bad any help is welcome. If a guy can fit a 30t and still use an oem belt then I'd go for it, but if you have to use an off brand belt......no way.
Old 09-07-2014, 12:34 PM
grbrown's Avatar
grbrown
grbrown is offline
Originally Posted by qtrracer
It is worth it if going 2 teeth requires a belt change to a non-oem belt that is prone to failure. I changed my 66t rear to a 68t rear which is equal to 1 tooth on the trans pulley and it was worth it.
Using the same approach I mentioned earlier, at 2,500 rpm that change of gearing will result in 2,500 x 68/66, giving 2,575rpm, virtually identical to a 31T on its own.
Old 09-07-2014, 01:27 PM
bklynbob's Avatar
bklynbob
bklynbob is offline
As an alternative,look at the Evo Industries 49 tooth clutch basket.......
Old 09-07-2014, 04:33 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
On an 2009 up 6th gear with stock size tire
3000 rpms 30 tooth = 73.7 Mph
2900 rpms 31 tooth = 73.6 Mph
2800 rpms 32 tooth = 73.4 Mph
3000 rpms with 49 tooth clutch basket = 73.8
With the 49 tooth basket gear do you have to change the primary chain.
Old 09-08-2014, 01:01 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
Yes, the chain comes with the basket.
Old 09-08-2014, 01:22 AM
mike5511's Avatar
mike5511
mike5511 is offline
I went to the 68 tooth on the rear and have a 31 for the front when I get to it. That will move my wheel back to very close to the original position = stock belt will work just fine.
Quick Reply: 31t trans pulley
