Wind deflector for 2015 trike
Another Option
Here's another option: put the soft lowers on the crash bars (http://www.leadermotorcycle.com/harl...n-rain-guards/). No real 'install' required, just slip on/off. Often times it cuts wind quite a bit (although could flow differently on a Trike than what I've personally experienced on a 2-wheel :-) Minus 5 here in MN today too. :-(
I appreciate all of the replys and I will explore them all.
As I mentioned before I had a 2013 model and there seems to be some differences around the forks that keep some of the 2013 stuff from mounting.
I like the idea of using the fork mounted wings but can't find any that work.
I don't know what the tank lifts are or how they would help but I will begin some research.
I did see a thread where someone made a Baffle that mounted across the forks
and blocked the air coming over the tank, but when I made a cardboard model it wouldn't mount on my forks.
Thanks again,
Graybeard1944
Thanks again,
Graybeard1944
Thanks again,
Graybeard1944
Thanks again,
Graybeard1944
I talked to Kim today at f4.
She said the Baker air wings for the ultra would fit fine on my 2015 and they think that they will eliminate a large portion of the air blast.
They seem to be less sure that the between the forks air deflector will not be a problem with the steering damper. They seem to think that the air wings may make it unnecessary anyway.
I would still like to see what anyone has been able to come up with on their own if they didn't mind sharing there knowledge.
Thanks Graybeard.
Thanks Graybeard.
Yea
I had the fork fangs on my road King and I really thought they worked great.
I just installed the tank lift and if The temp is ever above 30 degrees again I'm going to see if that helps. I would like to use the fangs if needed because they did work for wind. Not sure how you had to modifiy them. With lowers ect...
Hap
Hap
I'm thinking of going with these. I had Baker products in the ast and they're quality stuff...
http://www.bakerbuilt.com/bbairwings/page126.html
