How difficult handlebar replacement on 2015 FLRT .
Just wondering how difficult it is to replace the handle bars on a freewheeler trike. I will probably have someone else do the wrenching as I have exactly zero hours of experience with changing out bars.
I know the new trikes have the can bus electrics and also the throttle by wire , linked brakes etc. Does all this new stuff make a handle bar replacement an expensive venture. Just looking for information from anyone who has already done this to the freewheeler trike. I am thinking about 14 inch bars . Not something too drastic but a couple more inches my wounded shoulders would love. I have tried adjusting the stock bars every which way and they are just too short for long rides.
Thanks for any info. you may have.
Replaced many a set of bars. If you don't go more than 2" there should be enough slack in the cabling inside the bars. Clutch and break hoses may need extending. Going to Apes will require extending the wiring. Not hard, just tedious. Remember to stagger your solder joints.
Good Luck
Good Luck
Thanks
