Rims for 2001 fxdl? Want to replace the spokes..
OK.. I know that I read it somewhere, but which rims will fit on an 01 low rider? I want to go with mags now as the spokes won't come clean and I tried to do the spoke wraps today and failed.
I'm just going to buy some new rims and put new rubber and brakes on it at the same time..
I know that it is a 39 mm front end with 19 front and 16 rear.. What year's sporty rims are a direct swap?
Thank you.
Thank you.
99-earlier use 3/4" tapered roller bearings vs. 2000-later use sealed ball bearing
Because the 99-earlier hubs have a smaller centering/locator for the rotors and pulley, you would need replacements or a special bushing ring (that is available) for your originals.
The front wheel is a slightly narrower than your front wheel so you would need caliper spacers.
Getting 2000-later wheels is the best choice
