Do I need to re-balance?
Old Mar 28, 2017 | 08:35 AM
jqb12's Avatar
jqb12
Default Do I need to re-balance?
I recently bolted a rotor spacer onto my front wheel, and am now having some front brake issues. Could the wheel not be rotating evenly due to the extra weight of the spacer on the wheel? When I spin the wheel, off the ground, it appears to have a bit of side to side motion/wobble. I'm thinking maybe it needs re-balanced?
Old Mar 28, 2017 | 09:28 AM
13RoadKing's Avatar
13RoadKing
bad bearings or bent wheel, nothing to do with balancing.
Old Mar 28, 2017 | 09:45 AM
jqb12's Avatar
jqb12
OK, but the bike was fine until I installed the rotor spacer? Tough to believe the wheel is now bent, and the bearings bad?
Here's a scenario: My son's car slid on the ice and ended up sitting at a pretty good angle in a ditch with water, with temperatures around 15-20 degrees. It sat there for over an hour before we got it out. As we drove away, there was a serious pulsating/vibration going on. Front wheel that was in the water totally packed with mud/ice. As we drove on, it slowly improved. Stopping and hosed off all mud/ice from wheel and its good as new. Was told that the extra weight on that wheel, due to the mud/ice caused the big imbalance on the wheel and thus, the vibration.
Old Mar 28, 2017 | 11:08 AM
Shanebo's Avatar
Shanebo
Perhaps a picture of the wheel showing the new part in place would help with this question.
Making any change to the front wheel immediately prior to an issue like this showing up is worth a look.
Not sure how the wheel itself would bend, but perhaps the rotor itself? I've seen bent rotors from crashes before, and what you've bolted on might be neither square to the axle, or round and centered/balanced to the wheel itself.
Shane
Old Mar 28, 2017 | 11:23 AM
jqb12's Avatar
jqb12
So maybe just to be sure..............I should take the complete assembly with rotor spacer and all and make sure it's still running true and balanced with the addition of the spacer.
Old Mar 28, 2017 | 12:20 PM
13RoadKing's Avatar
13RoadKing
OK, this is pretty simple:
inner races of 2 wheel bearings seat pretty tight on axle (no free play). Same goes to outer races to wheel.
It comes to 3 possible problems:
1.axle is spinning if its nut and holders nuts are lose (not likely)
2.one of bearings (or both) are bad.
3. Wheel is bent.
There is one more possible problem (not likely), I bought some bike with the problem:
owner installed wheel bearings with smaller OD and i bought the bike dirt cheap!
Old Mar 28, 2017 | 02:53 PM
Shanebo's Avatar
Shanebo
That's what I would do in this case.
It should at least answer your question as to balance/true.
If the problem is inside the hub, at least you'll have the wheel off the bike to do whatever you need to at the time.
Shane
Old Mar 28, 2017 | 04:42 PM
hurst01's Avatar
hurst01
is the rotor running out also or just the wheel? Why was the spacer added? Is it a factory spacer of home made? How is it affecting the brakes?
It would have been easy to overlook and not notice a wobbling wheel before you added the spacer.. don't ask me how I know. How much wobble is there?. There is a big difference between wobble and balance and tknowing these things would help. I have used rotor spacer plenty of times with no problems.
tcarson84
Apr 12, 2016 06:12 PM
texashillcountry
EVO
20
Feb 11, 2015 03:12 PM
scaryonly
Wheels/Tires
Dec 3, 2009 12:15 PM
thomasf59
Oct 5, 2007 10:13 AM
thomasf59
Oct 4, 2007 08:27 PM
