2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Home grown external breather
Old 05-08-2015 | 04:31 PM
SafetyMan's Avatar
SafetyMan
A man would have to be looking for it to see the hose running next to my cylinder... it is outside of the push rod tubes. With the stock AC cover and the lower fairing, it's not somewhere people look at the bike.
Yes, it's there, but I went with black fuel line so it doesn't "stick out"
Old 05-08-2015 | 04:40 PM
lp's Avatar
lp
Well... I see it. But I'm always looking for it. Just a thing I guess.
It's not bad looking though - not that it matters what I think, but you're right. It kinda blends in with it being black and all.
Dig the 43 by the way. Ya'll Doofs be crazy.
Old 05-08-2015 | 04:55 PM
SafetyMan's Avatar
SafetyMan
Yeah, you see it in the picture, because that's what the picture is of....
But if you ran into me at the bar, you would be noticing a lot of other things first...
Old 05-08-2015 | 05:09 PM
2014streetglide's Avatar
2014streetglide
Is there a way to vent the stock AC right behind the AC itself instead of running the hose down?
Old 05-08-2015 | 05:32 PM
Smokey Stover's Avatar
Smokey Stover
I have found that the gunk flowing out the hoses has a bit of water vapor as well. It creates a kind of vaseline gunk that starts to narrow/clog lines and my catch can had a thick layer.
I still think I came up with one of the best/cleanest looking,invisible mods so far.If I do say so myself.
Copied and pasted my solution from one of the many threads about crankcase breather venting.
Also lots of good info, ideas, and photos in this thread,
https://www.hdforums.com/forum/touri...-included.html
This is what I came up with after being unable to find any system that would work with a SE stage one backplate, I went with dual hoses parallel to bottom of rocker box covers then down to hidden catch can in cowbell. Marine shrink wrap over fittings tapped into backplate really cleaned it up.
This is why. I didn't have a lot of oil drippng, But enough to make a mess on cam cover,pipes,side cover,and front of saddle bags if I didn't clean the filter every week or so. It looks like this because the moisture and oil are being shaken like a paint mixer in the cowbell. Glad this gunk isn't going in my intake.
link to my trial and error thread
https://www.hdforums.com/forum/engin...-pressure.html
Old 05-08-2015 | 05:51 PM
Yukon42's Avatar
Yukon42
Originally Posted by joenash
What did you do with the holes that are drilled into the cover ?
I believe you are referring to the stock breather channels drilled in the SE back plate.
I squeezed Ultra Black silicone into the holes till they came out in the "chambers" then tamped it down a bit in the chamber to form a type of "head" that couldn't slip back through the hole into the throttle body, just for added insurance. Make sure it's completely cured before using the back plate.
Old 05-09-2015 | 06:41 AM
SafetyMan's Avatar
SafetyMan
Exactly what I did.
Old 05-09-2015 | 06:42 AM
SafetyMan's Avatar
SafetyMan
Originally Posted by Smokey Stover
...hidden catch can in cowbell...
I hide my horn there.
Old 05-09-2015 | 12:56 PM
nuttbaggerr's Avatar
nuttbaggerr
That's really trick, but where do you mount your horn with thus mod?
Old 05-10-2015 | 07:25 PM
hapbob's Avatar
hapbob
Default Ow long
How long was it before you noticed that vasoline looking stuff appeared?
Hap
Quick Reply: Home grown external breather
