Home grown external breather
Here's my take on the external breather:
Decided to go "up" over the engine
Here it is installed on the engine:
Here it is with the AC cover installed; all but disappears!
Okay, here's the other side....see the breather line???
See it now???
Close up of the catch can. Pretty well hidden, but looks nice if it's spotted.
Did that this morning and installed a fuel moto header pipe. Next up wire in the PV2. Harley projects just keep piling up!!!
See it now???
I honestly don't think "up" is the answer, in order for the oil to seep, it is going to have to fill the mounts, hose, connector....
Also, is your can vented? Can't tell from the pic, if it's not vented, it will build pressure and blow something loose, probably the hose.
I said I would like to see what the chamber with the breather bolt looks like.
Reckon if it gets full enough, it will just run back into the head.
I figure the pressure will push air bubbles or whatever through the oil since the standing oil isn't under any pressure itself.
I've been wanting to do mine the same way because no one likes looking at those lines going down the sides of the cylinders. Hope these guys report back how it's working in a few before I get to it.
