2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
2016 FLHXS newb with questions
Old 05-28-2016, 06:46 PM
Robtarra39's Avatar
Robtarra39
Robtarra39 is offline
Default 2016 FLHXS newb with questions
Hi All , i just bought a 2016 FLHXS today and very excited about my purchase, not my first harley for sure, but this new bike is different from what i am familiar with and have a couple questions.
Will the vented lowers from an 06 work on this bike?
What cam are in these HO 103 motors?
Old 05-28-2016, 09:44 PM
jd05flhtci's Avatar
jd05flhtci
jd05flhtci is offline
Dont think the lowers will work without mods.
The cams are close to the se 255
Old 05-28-2016, 09:56 PM
PeteF's Avatar
PeteF
PeteF is offline
Harley shows different part numbers for lowers 2014 and up. However, it lists the same part number fitting a 2016 Tri Glide and a 2006 FLHX, so if you have a set lying around it might not hurt to give them a try and see how far off they are.
Old 05-31-2016, 04:02 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
I think it should fit with slight modifications on Rushmore models but since you don't have passing lamps probably no modification required. 2016 Tri Glide is no different then any other 14 and up Rushmore models it's probably an error.
Old 05-31-2016, 06:22 PM
jlasoftail's Avatar
jlasoftail
jlasoftail is offline
The newer lowers are different, but I don't think they fit different... My guess it that they will bolt right up.
Old 05-31-2016, 07:48 PM
Robtarra39's Avatar
Robtarra39
Well today i had a chance to mock them up, just need a little trimming to clear the rear brake master cylinder and they will mount up
Callahan86
03-09-2022 03:16 AM
ICIBUY
04-06-2015 07:09 PM
Jacket4256
10-31-2008 07:24 AM
sifularson
04-09-2008 05:54 PM
bigirn
02-19-2008 01:28 PM
Quick Reply: 2016 FLHXS newb with questions
