2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Bought and intalled new maps
Old 02-03-2017, 08:19 PM
CVO SG's Avatar
CVO SG
CVO SG is offline
Thanks, I'll update mine
Old 02-05-2017, 06:26 AM
russ33541's Avatar
russ33541
russ33541 is offline
Well I rode all day yesterday and played with the nav system. So far I have seen no difference from the previous version other than roads that were built in the last few years are now showing up.
I will keep playing and checking different things.
RandyJK (02-05-2017)
Old 02-05-2017, 09:18 AM
Roadie13's Avatar
Roadie13
Roadie13 is offline
Received 1,063 Likes on 509 Posts
Originally Posted by russ33541
Well I rode all day yesterday and played with the nav system. So far I have seen no difference from the previous version other than roads that were built in the last few years are now showing up. I will keep playing and checking different things.
The updated maps don't affect features or functionality at all. The only thing that should change is roads that have been added changed etc.
Old 02-05-2017, 09:23 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
To be fair, that is all a "map update" does.
It is only an updated map, and no other functions will change.
New roads built since the last update will show up, old roads that no longer exist are removed.
Pull out an old paper map and compare it to one from today and look at the differences.
GPS maps are no different.
Each user will have to determine if the cost to update is worth it to them.
Some areas of the country don't seem to have as many road changes as others, so to some its hard to justify the cost.
I bought a "lifetime" update for the Garmin I use in my truck a few years ago.
This is an older unit that didn't include the free lifetime updates.
I update the map about once a year.
So far, I haven't had the need to update the HD navigation yet.
It is weird sometimes riding down a new road, and have the GPS map show you riding in the field and the old road showing up a slight distance away.
Edit: Roadie13 beat me to it
Old 02-06-2017, 07:02 AM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
Originally Posted by TOFTS
At the price they want Ill just keep using google maps bluetoothed through the audio
If all you care about is A-B as fast as possible, and have continuous internet coverage on your phone, plus unlimited data, then that should work just fine.
I like to have my routes set up in advance and exactly the way I want to go, instead of A-B the fastest, so being able to use waypoints to lock in my route is very important. Having recent maps due to construction is a bonus, if nothing else so the b87th in my ear will quit recalculating, hahahaha.
Old 02-06-2017, 10:02 AM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
If you actually tour,, planning cross country trips, ridding to unfamiliar areas etc. and your maps are > 3 years old, then an update is probably worth it, as long as it is a current 16/17 update, but for my type of riding i'll just use the 3, 2 remaining, free updates because i get them, not because i need them.
For some reason I like the google maps on my iphone when in my cars/truck, that have NAV, better than the built in Nav presentation.
Old 02-07-2017, 02:24 PM
benningtonr's Avatar
benningtonr
benningtonr is offline
I loaded the new maps around the middle of Jan, I have had no issues. While loading on the bike I walked away and let it do it's thing, came back a hour or so later and it was all done. Mine also downloaded the first time I tried. There are more folks accessing the new maps now so that might be why it was so slow.
Old 02-11-2017, 12:24 PM
kepros's Avatar
kepros
kepros is offline
6th Gear
Default Important Nav Update
I am hitting the issue others have described with "Error: NavSync_NoNavContent" when trying to apply an "important" Nav update. A little leary of moving on to a map update when this small update doesn't seem to work.
  1. Add fingerprint to USB from bike
  2. Put USB in computer and open Naviextras
  3. Am told there is an "important update"
  4. Naviextras installs update to USB
  5. Put USB back in bike....always results in "Authenticating" followed by "Error: NavSync_NoNavContent"
Did others skip this "important" update and just go to downloading and updating an actual map?
Old 02-12-2017, 08:27 PM
greg09997's Avatar
greg09997
greg09997 is offline
Its not just the maps that are important to me. The POI's are updated as well. I use this often. It's nice to have more current info.
Took me 2 tries for the download.
Old 02-13-2017, 03:33 PM
Dutch101st's Avatar
Dutch101st
Dutch101st is offline
So I have a question...
My wife and I both ride (she has a '14 tri-glide ultra, I have a '15 SGS), both have the Infotainment system with the GPS- if we purchased one copy would we be able to install on BOTH systems? Or is this some kind or license keyed thing?
Caidly (02-14-2017)
Quick Reply: Bought and intalled new maps
