Navigation is stuck, can't cancel route keeps recalculating!!
04-30-2017, 12:37 PM
stuck on last address, cannot cancel, constantly recalculating and interrupting the music
04-30-2017, 12:46 PM
Could try a factory reset
Factory reset on infotainment: hold mute button, turn bike on to aux (from off) hold till accept screen. Press accept. Goto reset and select pre cal reset
04-30-2017, 12:48 PM
on the nav screen tap the box with the three lines in it and choose stop.
04-30-2017, 12:49 PM
04-30-2017, 12:59 PM
You'll have to drive to the destination before it will shut up! ☹️ Or you can do as suggested above and stop the route.... 👍
04-30-2017, 01:03 PM
Quote:
Originally Posted by
asm481
Yes as mentioned you must click on this icon and must select "Stop".
It becomes easy once you are used to it.
04-30-2017, 01:25 PM
i am sure pulling the maxi fuse for 10 min will completely lobotomize the thing... and start fresh
04-30-2017, 02:17 PM
My suggestion - plug in the headset, hit the button on the left (above the toggle switch) and say...Cancel route
04-30-2017, 02:22 PM
asm481
This !
04-30-2017, 03:09 PM
Shooting it will stop it. I suggest 00 buckshot.
The following 2 users liked this post by GalvTexGuy:
