No sound from speakers
Depends, could be many things. The obvious is to ensure your volume is turned up. Then check the settings to make sure you have your audio source sent to the speakers instead of the headset.
What don't you hear? Radio? Music on a USB drive? Navigation prompts? None of the above? No sound out of any of your speakers after, you've eliminated all of previous stuff as a suspect could mean a defect in your infotainment unit.
Worse case scenario, you'd need to repair/replace it. Do you have an ESP or other service plan? If so, and they cover the Boom Audio stuff, let them figure it out.
TimLScheffer (05-07-2019)
TimLScheffer (05-10-2019)
