Disappointing Stage IV Dyno Results: 2015 Limited
Old Jun 3, 2015 | 07:16 PM
bagabond's Avatar
bagabond
Default Disappointing Stage IV Dyno Results: 2015 Limited
Today I returned my 2015 Limited to the dealer for a dyno tune. The bike was equipped with a Pro Stage IV kit, SE race tuner, and 3.5 - inch Rinehart true duals before I took delivery about 2 weeks ago. The bike now has 1300 miles on it.
As shown on the attached dyno sheet, the best HP number is 18 HP below the advertised spec, whereas torque comes up about 15 ft-lb shy. The tuner spent approximately 2 hours with the bike.
As you might imagine, the dealer is blaming everything from the pipes to moon phase for the lack of performance. I am sorely disappointed and am looking for advice. I'm really hoping that there is someone on the forum with the same set up and a corresponding dyno sheet. Thanks in advance for any help.
File Type: pdf
Old Jun 3, 2015 | 07:24 PM
68 XLCH's Avatar
68 XLCH
Someone with some technical tuning knowledge will certainly comment.
My bike stage 1 87.48 HP and 106 Torque.
My airflow/fuel line is really tight and they stay on the line that i guess they are shooting for. Yours seems to not be dialed in.
Now i am not real savvy on any of this so wait for a few more tuner knowledgeable comments.
Old Jun 3, 2015 | 07:47 PM
senna's Avatar
senna
True duals will always kill the bottom end!
Old Jun 3, 2015 | 07:58 PM
GlidingJoe's Avatar
GlidingJoe
there has to be a local tuner who can do better than that... Your curve should be a nice 45 degree angle up to the peak, no dipps as your tune shows...
And yes to the comment "True Duals will mess with a good dyno bottom end"
Old Jun 3, 2015 | 08:17 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
You might miss a little with TDs on the low end, but they should give you better peak numbers with that build. My advice, find another tuner...
cpbedor's Avatar
cpbedor
What is your setup? What heads, pistons, cams and throttle body?
Those numbers are NOT stage 4 numbers. Not even close. I have a stage 4 dyno sheet but I doubt it's similar to what you're running.
Two threads to search for that may have your info. On Touring: Dyno Numbers for Baggers. It's s sticky at the top of the page as well as one here in Rushmore I think called Rushmore Dyno Numbers.
Good luck.
Old Jun 3, 2015 | 08:31 PM
bagabond's Avatar
bagabond
Thanks guys,
The Pro Stage IV Kit- 103 cu in. details are:
- PN 92500018 (p. 61 2015 SE catalog)
- CNC-ported heads with hi-performance valve springs
- 10.5:1 pistons
- SE-259 cams
- 58 mm throttle body
- Screamin' Eagle Super Tuner
I expected to lose some low-end torque but the top end numbers are brutally low for Torque and HP. It's going to be a time and energy sucking pissing match with the dealer. It's certainly not how I wanted to get started with this new bike.
Old Jun 3, 2015 | 08:43 PM
jurgie's Avatar
jurgie
Thanks guys,
- 10.5:1 pistons
- SE-259 cams
rRun from that place.As said find a good tuner in your area.
Old Jun 3, 2015 | 08:49 PM
cpbedor's Avatar
cpbedor
Unless they forgot to put in half the parts that came in the kit, you should definitely be getting better numbers. Bite the bullet on the $400 it will cost you to have it tuned right somewhere else. They clearly don't know how to tune it. Very modestly speaking, you should be at least at 110/110. Even with your pipe.
Old Jun 3, 2015 | 09:00 PM
rmc115's Avatar
rmc115
Anybody notice they started the runs at 1600 rpm? That is hard on the crank whacking wide open that low. Every run i have looked at started at least 2000. Mike
